THE C64: Vic20 CJM files ?
Mikam73
2049er
Post by Mikam73 »
Does someone have The C64: Vic20 CJM files for different memory settings?
Witzo
Re: THE C64: Vic20 CJM files ?
Post by Witzo »
I tried cjm-files with just a single line:
X:vic,pal,bank0,bank1,bank2,bank3,bank5
and:
X:vic,pal,35k
with the same name as a .d64-file.
But it doesn't do anything. Inserting the .d64 and going to the VIC, pressing the 'run' button on the image, or resetting the VIC just keeps it at 3.5KB.
The image doesn't yet contain any files. Is the cjm only read when 'run' is pressed on the image and the is a first program on the disk to run?
Flags on the disk image filename do work for me.
Like:
vicdisk_MVTPB0B1B2B3B5.d64
Mikam73
2049er
Post by Mikam73 »
Also I can’t get CJM files work. I have loads of TAP etc files at different memory directorys and wouldn’t wanna rename all files again. CJM file supposed do that for whole directory.
Witzo
Post by Witzo »
I made a rookie mistake: Windows was hiding file extensions, so my file was named vicdisk.cjm.txt in stead of vicdisk.cjm.
I found out when I plugged the USB in a Linux system. And fixed the file names there.
On TheC64, I insert the disk image, choose the 'run' option with the rocket, and then the cjm works.
Mikam73
2049er
Post by Mikam73 »
It doesn’t work with tap files if just choose tap file to load.
