HELP! MEGA CART TROUBLES!
Spectrum
Website: https://www.facebook.com/honeyvenom666/
Occupation: comic artist
Post by Spectrum »
Hello everybody!
I have a big issue about my Mega Cart. It always worked well, but suddenly the available games became just few (5 or 6). This is true both for the cartridge and the tape games. I think the utilities and the demos are OK.
I tried the Mega Cart on two different Vic and I already cleaned the cartridge. What could it be?
Any idea?
I am very sad, the Mega Cart is my fav tool on the Vic20. :cry:
Re: HELP! MEGA CART TROUBLES!
Have you tried resetting the nvram where the config is stored? Tells you how in the instructions.
Or maybe you have a filter applied that shows only some games.
Yeah, my first thought is a filter applied.
Spectrum
Post by Spectrum »
beamrider wrote:Have you tried resetting the nvram where the config is stored? Tells you how in the instructions.
Hi!
Thank you for your reply!
I did not. I will try. I checked the instructions but I didn't notice such possibility. I was too much in PANIC! lol
Other friends here are saying that it could also be a problem related to the filters.
I will check my MegaCart as soon as possible.
Thanks for your help!
Spectrum
Post by Spectrum »
tokra wrote:Or maybe you have a filter applied that shows only some games.
Perhaps I just did it by mistake. I will check it.
Thank you for your help, and sorry for my late in reply. I was so busy through the last days.
I will let you know what's going on with my MegaCart as soon as possible!
Spectrum
Post by Spectrum »
Mayhem wrote:Yeah, my first thought is a filter applied.
Thank you!
I will check the filters. I don't remember I applied any filter, but maybe I did it by mistake.
Spectrum
Post by Spectrum »
Thank you everybody!
The problem was the filter indeed.
I was so panicked that I didn't properly check the Cart and all the possibilities.
I'm SO happy!
