what is the best way to load TAP files on a VIC 20?
lucifershalo
Post by lucifershalo »
Are there "modern" easy ways ?
or the easiest is to find a tape recorder?
lucifershalo
lordbubsy
Post by lordbubsy »
lucifershalo wrote:does this work for the Vic20?
Yes, that works quite well. Those interfaces come in various flavors, but are basically an audio to C64 / VIC-20 / C128 digital (TTL) signal converter.
I have a similar device from the 80's and connected it to a cell phone.
If you’re devoted enough, you can even put pictures of the tape covers in the mp3's. 8-)
The only back draw is that the computer can't stop the tape, which in some cases is necessary.
8-bit assimilation
