The power light for the uIEC comes on and the green light does it's wee on-then-off thing but when I did a LOAD"$",8 all I get is the DEVICE NOT PRESENT error! Why wouldn't this work? Any ideas? Thanks, P
The standard setting for the uIEC is drive 10.Pedro Lambrini wrote:The power light for the uIEC comes on and the green light does it's wee on-then-off thing but when I did a LOAD"$",8 all I get is the DEVICE NOT PRESENT error! Why wouldn't this work?
Check your connections once more, you probably swapped some of the signal lines.Pedro Lambrini wrote:The power light for the uIEC comes on and the green light does it's wee on-then-off thing but when I did a LOAD"$",8 all I get is the DEVICE NOT PRESENT error! Why wouldn't this work? Any ideas?
You can run the LED output through a 7404 or 7406 inverter IC to do that.Pedro Lambrini wrote:Just as a follow-on to this wee project I was wondering if it is possible to wire the LED's on the uIEC so that the 'disc access' light would stay on permanently but still go off and on during access time?
ClosePedro Lambrini wrote:Too cool! Before reading the next bit of my post please excuse me as I've never done anything like this before. This whole idea is more about my imagination taking over from my knowledge...
So, if I understand this, I would take the output of the LED part of the uIEC PCB and wire it to pins 7 & 14 of the 7404 and then wire a LED to any of the Not gates, say pins 1&2. That would do the job?
