4 player adapter
4 player adapter
I would like to fit a 4 player adapter into a vic20 internally does anyone have a schematic of the standard 4 palyer adapter such as the protovision one ???
Also is there any software for the vic to take advantage of the extra joystik ports?
thanks
shem...
thanks
shem...
I'll take my cart to go thank you
Exactly the game mentioned from Carlsson, there is no other game for the vic that support the additional Joystick using this addon btw it seems very easy to write a new oneshem wrote:Thanks carlsson
Well its a start at least
I have paid for the megacart should be with me in a few weeks
any games on the megacart that support 2 player joustiks??
Enjoy your new Mega-Cart
- Mayhem
- High Bidder
Re: 4 palyer adapter
Actually on Protovision's own web site they have sketchy drawings on which pins you use on the user port, how you wire up the 74LS257 and connect the joystick ports.shem wrote:does anyone have a schematic of the standard 4 player adapter such as the protovision one ???
http://www.protovision-online.de/hardw/build4player.htm
Since only PB0-PB7, GND and +5V are used, I believe the exact same interface will work on a VIC-20 too.
Groepaz/Hitmen refers to the Protovision interface as "classical games adapter". Also check the "DXS/HIT Adapter" which seems to be an improved design eliminating the TTL IC.
http://hitmen.c02.at/html/hardware.html
Of course the question is whether the OEM games use the parallel port in the same way as either of these interfaces do. The only way to find out would be to build an adapter, plug it in and observe what happens on screen. Well, we could disassemble the games and look for code reading the VIA chip too.
I know e5frog and a few more recently built their own Protovision-style interfaces into C64C's. I suppose the experiences gained from that experiment would be useful even with your VIC-20.
I'm guessing a few months at least. There are a lot of people ahead of you that pre-ordered. Each cartridge is made by hand, one at a time.English Invader wrote:I've just ordered a Mega Cart. The website said it would send an e-mail for payment and shipping details, and it's been about three days. Does anyone know how long I should expect to wait for a response?
A reply to each new order (order confirmation) is usually made within 1 business day.English Invader wrote:I've just ordered a Mega Cart. The website said it would send an e-mail for payment and shipping details, and it's been about three days. Does anyone know how long I should expect to wait for a response?
Request for payment is not made until about 1 week before shipping date.
If you have not received reply to order (order confirmation), please check to ensure reply message was not spam filtered. If still no message found, please use info button on mega-cart web site to send follow up message.
All these game are on Mega-CartMayhem wrote:Actually Amazing Maze, Space Ric-o-shay and Tank Wars (all from OEM) use the adapter for two player simultaneous action. So that's four games.
- Schema
- factor
A relevant disassembly of Amazing Maze may give us some hints. At $A0B8 and forward, it checks $9110 four times:
If $9110 AND 128 = 0, store #$01 to $00
If $9110 AND 64 = 0, store #$03 to $00
If $9110 AND 32 = 0, store #$02 to $00
If $9110 AND 16 = 0, store #$00 to $00
otherwise store #$04 to $00
This routine is called twice, from $A697 and $AA97. If $00 is not #$04, it reads an indexed offset from $A0EF:
$A0EF: $01 $96 $81 $16
Offsets < 128 are added to the value of $01, $02 and dealt further with. All offsets are AND 127.
If I understand those numbers correctly, we get the following:
$9110 AND 128 = up
$9110 AND 64 = down
$9110 AND 32 = left
$9110 AND 16 = right
Which pins on the user ports those bits represent, I can't be bothered to look up at this minute, but someone could compare with the programming examples for the Protovision adapter.
$9110 AND 128 = up
$9110 AND 64 = down
$9110 AND 32 = left
