Strange noodling while preparing to meet up with arch Swedish coder tomorrow evening in Vasteras.
How about a loader programme that could read VICE snapshot files.
e.g. Read Snapshot header containing states into tape buffer, load bulk of memory back into place , poke all the states back into place and jump to execution pointer?
Probably not possible and more likely not even needed just wondered if it could be done.
It would be handy for saving high scores. That always drove me crazy about Vic games. Why couldn't they be coded to allow you to insert a blank tape or something and save you scores to that, why?!
Obviously, as an adult I'm a little more philosophical about this situation but Ians suggestion could be good if it's possible.
Something like this has been done by 1570 for the C64DTV emulation in vice.
It is a PC program that converts a snapshot file into an executable file for the DTV.
here: VSFReanimator
Thanks TLR. Nice to know crazy ideas are not that crazy sometimes.
It could basically give us the ability to high score save or pause and continue anything on the Vic.
Imagine, plug a cart in the vic with SD card support, when you hit reset the Vic state is dumped to SD card in Vice snapshot format. Load it back up in Vice or reset the vic and reload from the SD at a later time.
The cart could be simpler if it was used in conjunction with uIEC.
Vic20-Ian wrote:Imagine, plug a cart in the vic with SD card support, when you hit reset the Vic state is dumped to SD card in Vice snapshot format. Load it back up in Vice or reset the vic and reload from the SD at a later time.
This is basically what a freezer does for the c64.
Implementing it for the vic-20 is non-trivial because of architectural differences.
Yes basically it is a freezer cart idea but I would like to extend it so that the frozen image could be used with Vice away from home on a laptop and then a vice snapshot with new highscores could be put on SD card and loaded back to the real Vic20
