how can I load and play a multi-cartridge (f.e. Outworld *.a0 & *.6000)
in winvice, without using the Vic20GB (Gemus-script) ?
I know GB20 is a great program to archiving & playing Vic-Games.
And of course I use it, too. (not only for the Vic, I use all Gamebases)
But there is also the ECC. Short for Emu Control Center.
With this Programm you can collecting & archiving about 100 old & new
Computer-Systems.
The Programmer "Andreas" (ECC) & "Sebastiaan" (Phoenix) are doing a good Job.
I'm just a Member of ecc and collect infos for the "romdb" , put Screenshots to the Vic20 database (Image-packs). - However......
But the Problem is : You can't use the Gemus-Script with ECC.
At this Time, you can only start "*.prg's" with ECC automaticly, by using a Script incl. "PRGIndo.exe"......
"Phoenix" is just working on a Script, to start all Fileextensions with ECC.
And I think he will do !!!
But of course, he is not a Vic20-Freak, and so I think there will be much trouble to run Multi-Cartridges & Multi-Prg's .
The only way I know, how to use the multi-prg's, is to make a *.d64.....
If someone of you can help a little bit, (if Phoenix needs help) i'll be very gratefull !
btw.
You can also help, to fill the romdb with Info's for Vic-Games.....
I've allready add many Games. But I think there are still "Metadata" - Errors in it. (programmer, publisher, etc.)
Of course, you can also make Entrys for all other Computers, Consoles & Handhelds
At last I wanted to say : ECC isn't a Competition or Opponent to Gamebase.....It's just another Cool Program for all Retro-Collectors !
Here are a few links if you're interested :
The ECC-Forum (English) : http://ecc.phoenixinteractive.mine.nu/index.php
The ECC - GameDatabase : http://www.camya.com/gamedb/
ECC - Website : http://www.camya.com/eccblog/
The Vic-20 - Script-Topic : http://ecc.phoenixinteractive.mine.nu/v ... =51&t=2399
