Hello,
I am afraid I have a damage on my VIC-20, so I ask to do a test on your VIC just to see if we get identical results.
I was thinking about building myself paddles but I see that the following program:
10 PRINT PEEK(36872);PEEK(36873):GOTO 10
gives me a series of 0 - 0 pairs, which does not look right.
I have read that these number represent the value of the resistance expressed by the potentiometer (the paddle, but I did not plug enything at all yet!).
So a zero value means zero resistance = paddle at all left = short circuit.
I have also read that the default value when there is nothing connected to the game port should be 255 for both columns.
If you try the above single-line program onto your physical VIC-20, what do you get?
Thanks in advance to anybody willing to try it!
Help needed: default paddle readings
- Website: https://vic20reloaded.com
- Occupation: programmer
- TheVic20User
Re: Help needed: default paddle readings
Thanks, this looks correct. 255=Max resistance=No paddles.
I definitely think mine has got a problem because I only get a list of zeroes.
