Winter is almost here for me again, and I am planning to take on another crazy retro project this year.
This time, an expansion system that will bring my VIC-20 up a few levels in audio / video power.
This project will be called The VIC-2000 Expansion Module, or just V2K for short.
I am doing this as a personal challenge, and have no intentions of doing it the "easy" way.
I really enjoy 6502 assembly, and intend for my VIC to become a very usable development system.
Here are my goals and rules. I always set out strict rules to make the challenge more difficult.
**** GOALS ****
1) The VIC-20 cannot be altered on the inside in any way. It must remain pristine.
2) Video must be VGA with a minimum of 400x600 or 640x480 resolution.
3) Color palette must be at least 4096 colors on the screen simultaneously.
4) The VIC will be able to access 16 Megabytes of super fast Audio / Video memory.
5) A blitter system will be capable of drawing sprites if any size at 8MHZ minimum bandwidth.
6) Sound will be at least 4 channels of 8 bit sampled sound.
**** RULES ****
1) Only VIC-20 era logic components and static memory may be used.
2) All chips must be DIP format, and all testing will be done on a breadboard.
3) All chips must still be available and produced by more than one company today.
4) No special ICs such as FPGAs, GALs, or even ROMs will be used. Just pure 74 logic.
5) The entire V2K system must plug into the back of an unmodified VIC-20.
The above goals and rules are set in stone.
Other than that, the project will evolve as I start to work on it.
At this point, I am still considering options, such as what to do with the original 6560 output.
I am planning a full redo of the OS / Kernal, and instead of Basic, I will boot in an assembler / IDE.
The original VIC will be running the show, but I will probably end up with a second 6502 in my system as well.
I am thinking about having the VIC run the OS / Assembler, and it will assemble to the secondary 6502 for execution.
Such a system would basically be a "6502 Core-II Vic-20".
Much of the work on the video system shall be taken from my previous 6502 mega project called Vulcan-74.
Living a homesteading lifestyle, I am still very busy with outdoor work, so progress will be slow until the deep freeze.
Until I have some free time, let me end with my first project photo...
Fresh out of the box, my original stock VIC-20 still ready to rock!
Talk to you deniers soon... thanks for defending the faith!
- Radical Brad
