Is it possible? .prg files to .wav files?
pms
Post by pms »
Ok, after 5 years I tried my old Vic-20 and it works great!
I'm supprised that most of my old tapes are still working.
But sadly enough, not my most loved game: Matrix
I found matrix as a .prg file on the internet.
Works ok on the Vice emulator but...
I want it to run on the real thing: using the Atari joystick!
So is there a way to convert this prg file to the Vic?
Is there software wich can create a .wav file on the pc so I can put in on tape and load it?
Ok , I'l try to get to level 10 on the emulator for one more tim...using the keyboard...
tlr
Re: Is it possible? .prg files to .wav files?
Post by tlr »
pms wrote:So is there a way to convert this prg file to the Vic?
Try Wav-prg, it should do the trick.
