Vic is now grey
Vic is now grey
Hi there.
The colors of my vic are now suddenly grey.
Before, after a few minutes the colors suddenly popped back now that won't happen anymore...
I feed the vic with 5V from a PC PSU since i don't have a 9V one that is powerful enough to power the vic.
Its a Pal one.
Is it common? I tried alot of different things except working on the motherboard itself....
-exin
Its a Pal one.
-exin
good copy tool wanted for the vic!
My own VIC starts out grey sometimes and will only go to colour after a few minutes or if I just toggle the colours randomly:
After some seconds it pops to colour then...
0 poke36879,rnd(1)*256:run
You need to adjust one of those little adjustment screws inside of the vic-20 located near your vic chip.
- e5frog
- Vic 20 Nerd
- Website: http://channelf.se
Are you feeding the VIC 5VDC only?
I read recently that you can feed a VIC 20 CR (the one with the circular DIN power connector) with 12V on the 9VAC pins.
Do you have the "two prong" or VIC 20 CR?
If you have the two prong version, I hope you feed the 5V after VR1 or some other clever location.
The 9VAC is really only used for the datassette motor and output on the user port, right?
Start by turning up the color on your TV/monitor and maybe try it on another TV/monitor just to check it's not that. Tuning the TV might help (if you use RF).
Why would you like to do that?e5frog wrote: I read recently that you can feed a VIC 20 CR (the one with the circular DIN power connector) with 12V on the 9VAC pins.
- e5frog
- Vic 20 Nerd
For the obvious reason... if you don't have a supply that fits and you perhaps have a PC PSU or Amiga PSU or other - that has +5V and +12V.
Not something I'd like to do, just something that's possible - just like you can run a NES on DC voltage even if it originally has an AC adapter.
It looks like +5V is enough though but you can't use the datassette if you do.
Another thing you might want to try is to re-seat the VIC-chip, if there's too much oxidation between pin 2 and it's socket (if any) it might be a problem. Possibly one of the caps is broken but that's not a very common problem. Adjusting the pot/s might help as mentioned.
- e5frog
- Vic 20 Nerd
Isn't there a frequency adjust knob somewhere that affects the color encoding frequency as well?
The colour carrier frequency is coupled to the CPU clock. It is most probably de-tuned on your VIC-20.
Some TVs accept a wider deviation of the colour carrier frequency from the ITU norm, others don't. If your VIC-20 is outside that margin for a given TV/monitor, you only get a grey picture.
I'd recommend setting a frequency counter on the clock generator. Adjust the circuit to the correct frequency just as the VIC-20 has been started, mark that position on the variable capacitor, then do the same after warm-up (say, 20 minutes), mark this position also, and then set the capacitor to the middle of the two positions.
Then you have good chances you get colour on all 3 displays, right after start-up, and also when the VIC-20 has warmed up.
- e5frog
- Vic 20 Nerd
Yes, or your oscilloscope or maybe other >$1000 equipment that people with VIC-20:s usually have.
If you make a mark of the current position you could try small adjustments and see if you get any color, if it doesn't work out then just set it back to the original position and forget about the tricky TVs.
