CrAlt
Post
by CrAlt »
Can the memory locations be changed on this cart to put some ram on BLK5?
I opened it up and there seems to be jumper pads for setting something.
6502dude
- megacart
Post
by 6502dude »
Quick and dirty fix to make 8K accessinble in /BLK5 area
- remove solder blob shorting between pads designated "1"
- add new solder blob to make short between pads designated "4"
I think this will leave your with 8K in /Blk5 and 8K in /BLK3
If you want more flexibility, then open all shorting pads, clean out solder from DIP pads & install a couple of 8 pin DIP switches.
This will give you flexibility to put memory where you want it, with flip of a few switches.
