Track&Field (Yleisurheilu) for Vic20 and C64 TAP files
Vic20:
http://www.megaupload.com/?d=0L9ZWJX8
C64:
http://www.megaupload.com/?d=1L40S33E
Should work now
C64:
Should work now
I didn't have much luck with those. The first freezes up my VIC-20 and the second one causes my 64 to crash. I also can't get a proper look at what's on the 64's TAP (which is odd, the VIC one works fine). Anyway. what is the difference between the 64 version and the ones in the GameBase64 (this and this)? I'm intrigued by why you posted this.
That was one commercial ridden site, if I ever saw one!
Anyway, I managed to load the VIC-20 version in WinVICE 1.22 but I don't have a clue how to play it. It seems you need at least 8K expansion.
Hm, from analysing the Basic listing it looks like this game relies on paddles. Is that so, Mika? Unfortunately it makes it unplayable through emulation and so also for many of us on real hardware.
Hm, in the C64 version you can play with joystick. On the other hand, it seems awfully primitive. By pulling the joystick upwards to a maximum, you keep running. I don't know if you can run faster by pulling it down sometimes. Probably the difference between VIC and C64 versions is that the VIC only has one joystick port and in order to allow two simultaneous players, they had to make it play with paddles.
Yes. It uses paddles and needs 8k mem expander. Only ´Track & Field´ game for Vic20 (so far) that I know.
C64 version looks really like basic game, I can imagine that it wouldnt sell very well, course there was games like Summer Games etc that looked lot better.
I wasnt even sure that '*Amersoft did made C64 version, before I managed find tape.
But lets talk more about Vic20 game
I remember that there was little program at tape that you needed load to calibrate paddles first.
May I suggest Sport Sport by Aleksi Eeben/CNCD 2002?
It can be found on VIC-20 Demodisk #1, and is rather a graphical demo than a full fledged T&F game. However I believe he or someone else could expand on it to become a complete game if the desire is high.
http://server.zimmers.net/anonftp/pub/c ... index.html
I dont have disc version. I have never seen any and dont think that there is disc version of this game. Disc drives were so rare and expensive.nbla000 wrote:Very hard work, it use protections and there are 14 files to fix inside the tap
Dump the original disk version if any, sorry.
Its protected somehow? I didnt think that Vic20 games had protections usually and wouldnt believe that they use things like that at Finland. But I dont know.
14 files. Looks like everyevent is different file and also paddle calibration is one.
Yes, try to load it just typing "LOAD" not CBM+SHIFT, it runs anyway.Mikam73 wrote:Its protected somehow?
I don't know in Finland but games protections on Vic-20 wasn't unusual.I didnt think that Vic20 games had protections usually and wouldnt believe that they use things like that at Finland. But I dont know.
The problem for 14 files is that you need to check each one to see how they load the next part and change the code to allow disk loading, i don't know Finnish and VICE do not support paddle Emulation, there are a lot of obstacles and works.14 files. Looks like everyevent is different file and also paddle calibration is one.
Maybe Carlsson may help you.
There is a SYS call which lets you load the tape buffer and stops:
SYS 63407
From there one can disassemble the buffer and make neccessary changes to continue the loading:
SYS 62980
The buffer also tells where each file goes into the memory.
On the other hand, aren't there already tools to extract individual files from a TAP? I think of wav-prg and perhaps cbmconvert. If the 14 files can be extracted, half the job is done.
I'll see if I can spend some time on this tonight or in the weekend. I have a few other projects ongoing that are more urgent.
SYS 63407
SYS 62980
Don't know if it can be of help, but I managed to obtain a t64 file and a d64 from the tap. There, you can see the single 14 files. The t64 works; the d64 obviously hangs at the very beginning.
I tried the game, but I'm not so good in Ugro-Finnish languages...
Seems like it's VERY basic:
The Paddles calibration id done via "Paddlen Saato" (easy enough to understand):
Other files don't seem to load, if you don't start from the first one.
Apparently, it accepts one player only, so maybe it can be played with the joystick.
Interesting btw for this game after the SYS63407, the buffer do not contain code and, without modifies, after the SYS62980, the Vic crashes.carlsson wrote:There is a SYS call which lets you load the tape buffer and stops:
SYS 63407
SYS 62980
OK then half the job is done, you may download the D64 file with all programs with same name and in the same order of the TAP file but the game doesn't work of course, i've used wav-prg.On the other hand, aren't there already tools to extract individual files from a TAP? I think of wav-prg and perhaps cbmconvert. If the 14 files can be extracted, half the job is done.
OK, may you translate it too ?I'll see if I can spend some time on this tonight or in the weekend. I have a few other projects ongoing that are more urgent.
Edit: Hey Orion we have done the same work in the same time, but aren't you busy like me on PaperSoft Project
