Custom Character calculator program
Hi, on the main page of DENIAL there is shown sometimes a program that looks like a designer's aid for making custom characters. It has a grid for plotting pixels and then calculates the values for the data statements.
Is there anywhere I can get a program like this that will run on an NTSC VIC-20?
It's only programs that changes screen position in a stupid way, rely on the raster beam or on exact sound frequencies that are incompatible between PAL/NTSC.
...or that makes use of the NTSC interlace mode...
...or exact calculation speed
No, only more raster lines, which makes no difference in this case.ral-clan wrote:Yeah, but don't PAL VIC-20s have more horizontal character rows than NTSC VICs?
That's why I thought this program would be incompatible: some of the lines of the screen would be off the bottom of my NTSC monitor.
Bacon
Definately from Germany and PAL, it's from me
But since I do not change anything regarding screen resolution or position it should be no problem at all on NTSC - just tested it on VICE in NTSC and worked very well (as I expected).
So, I'm off for a week so I won't answer any questions but since Greyghost has used LCE a lot I think it is now as flawless as I am able to program
Björg
Björg
- Schema
- factor
Re: Custom Character calculator program
http://sleepingelephant.com/ipw-web/bul ... .php?t=892ral-clan wrote:Hi, on the main page of DENIAL there is shown sometimes a program that looks like a designer's aid for making custom characters. It has a grid for plotting pixels and then calculates the values for the data statements.
