Leeeeee
soldering master
Posts: 396 Joined: Fri Apr 23, 2004 8:14 am
Post
by Leeeeee » Sun Mar 28, 2010 9:18 pm
Yes, to filter the +5V that goes to one end of the pots.
7 ---\/\/\/--+------ 7
FROM ----- TO
VIC 470uF ----- PADDLE
8 -----------+------ 8
Note that the resistor is 100 ohms not 100k. This should give a 3dB point of somewhere around 22Hz. Use a low ESR electrolytic or add a 100nF caramic in parallel.
This shouldn't make a lot of difference if any to the pot range.
Lee.
nbla000
Salmon Run
Posts: 2582 Joined: Thu Oct 13, 2005 8:58 am
Post
by nbla000 » Mon Mar 29, 2010 2:21 am
Leeeeee wrote: Yes, to filter the +5V that goes to one end of the pots....
But this is a motherboard modify or it could be an external modify to plug on the joy port ?
I prefer an external solution with a male-female joy plug without any internal modification.
Mega-Cart : the cartridge you plug in once and for all.
Pedro Lambrini
Posts: 1132 Joined: Mon Dec 01, 2008 11:36 am
Post
by Pedro Lambrini » Mon Mar 29, 2010 3:32 am
Wow! I've been away for a couple of days and had the worst 'net access. I've been able to read the posts but not respond but, boy, it's good to see some development!
Of course, an external solution would be the best but at the very least it would be great to finally pinpoint the problem so there's a better understanding of the fault.
Well done Ian for changing out the caps - that was way more brave than I would've been! I presume after your experiment I shouldn't bother buying the caps from Maplin then?
Posts: 1224 Joined: Sun Aug 24, 2008 1:58 pm
Post
by Vic20-Ian » Mon Mar 29, 2010 5:01 am
Pedro,
Don't bother with the caps I mentioned previously.
Please get 8 off 470uF Electrolytic and 8 off 100nF ceramics and 8 off 100 ohm resistors. Also a 1 female 9 way D connector and 1 male 9 way D sub.
This will give me and you a set of caps to try on a paddle mod later this week and another set for an adaptor or two for any unmodified paddle set.
It will be easy for me to do this mod on an existing set of paddles in a reversible manner. I tried but with wrong cap sizes at the weekend.
The disadvantage of doing it on the paddle is that it needs 2x capacitors, 1 for each paddle. The advantage is that it will be invisible / no adaptor.
At this time it looks like no motherboard mod is required. More later this week.
nbla000
Salmon Run
Post
by nbla000 » Mon Mar 29, 2010 5:15 am
Vic20-Ian wrote: At this time it looks like no motherboard mod is required. More later this week.
Wow this is a very good news, maybe a first step for en external adaptor!
Leeeeee
soldering master
Post
by Leeeeee » Mon Mar 29, 2010 5:21 pm
You only need one of each component as only the +5V line to the paddles needs to be filtered. The other lines should all pass through unmolested.
Lee.
Commander#1
Posts: 38 Joined: Wed Feb 25, 2009 1:48 am
Post
by Commander#1 » Mon Mar 29, 2010 9:48 pm
I find this rather interesting. I just read a blurb about 'jittery paddles' in the WIKI section - come here to find that that is
the lastest issue to be discussed, go back to WIKI to document it and all I get there is a screen full of crap! AARRRRGG!!
Can someone tell me what's going on around here!!
Phil Potter.
The earth is - oh my gosh - ROUND ! !
nbla000
Salmon Run
Post
by nbla000 » Tue Mar 30, 2010 2:57 am
Leeeeee wrote: You only need one of each component as only the +5V line to the paddles needs to be filtered. The other lines should all pass through unmolested.
So you mean that we can build an external interface with a 100nF caramic in parallel on joy pin 7 and a bridge with the 470uF between Pin7 and 8
_________________
\ o5 o4 o3 o2 o1/
\ o9 o8 o7 o6 /
\___________/
Pin Joystick
1 Forward
2 Back
3 Left
4 Right
5 -
6 Button 1
7 +5V *
8 GND
9 -
<-- Male connector to the Vic
1|---UP--------------------------------------|1
2|---DOWN------------------------------------|2
3|---LEFT------------------------------------|3
4|---RIGHT-----------------------------------|4
5| /--------------------\ |5
6|---FIRE-/ /---100nF------\ \---------|6
7|---+5V---/ |+ \--------------|7
8|---GND-\ 470uF /--------------|8
9| \ -| / |9
Female connector to the Paddle -->
Is this right ?
amramsey
Posts: 117 Joined: Sat Apr 14, 2007 9:38 pm
Post
by amramsey » Tue Mar 30, 2010 3:29 am
That is the idea, but a 100 ohm resistor on line 7, not a cap.
nbla000
Salmon Run
Post
by nbla000 » Tue Mar 30, 2010 5:18 am
amramsey wrote: That is the idea, but a 100 ohm resistor on line 7, not a cap.
ah ok so this is the correct diagram, right ?
6|---FIRE-/ /--100ohm-------\ \---------|6
9| \ -| / |9
Post
by Vic20-Ian » Tue Mar 30, 2010 5:30 am
yes, Pedro and I will be testing later this week.
nbla000
Salmon Run
Post
by nbla000 » Tue Mar 30, 2010 7:07 am
Vic20-Ian wrote: yes, Pedro and I will be testing later this week.
Wow very good news !!!
Please report us results
Pedro Lambrini
Post
by Pedro Lambrini » Tue Mar 30, 2010 7:58 am
Yeah, I'll go to Maplin with my shopping list tomorrow. I was going to go today but the weather is just ridiculously bad!
Post
by Vic20-Ian » Tue Mar 30, 2010 8:45 am
I have never met a rusty person yet
Leeeeee
soldering master
Post
by Leeeeee » Tue Mar 30, 2010 3:28 pm
As pins 5 and 9 are the POTY and POTX pins it would probably be best to connect them straight through as well. 8^)=
Lee.
