theSmiths
Post
by theSmiths »
What is the best way of cleaning the datasette heads?
With the liquid tape cleaner?
Or
With the fluffy tape cleaner?
Many stores in the UK still stock tape cleaners.
But i wish to use the correct one,without
Shortening the life span of my Vic.
Post
by Mike »
I use pure Isopropanol and Q-Tips for cleaning tape heads.
You should also clean the rubber of the transport cylinder off tape dust. That's easiest to do while PLAY is pushed down.
- High Bidder
Post
by Mayhem »
Q-Tips... that's cotton buds to us by the way Smith
But yeah, do the same thing, clean the heads and the rollers of all dirt, you'd be amazed how much can come off old tapes...
theSmiths
Post
by theSmiths »
Ah great stuff Guys...
I will give that a go then...
Many thanks for your help!
