20RDLE
20RDLE
If you haven't been hiding under large rocks the last few weeks, you know that this damn thing is all the rage. So why shouldn't we have it on the VIC-20?
20RDLE is a WORDLE implementation for a VIC-20 with 24K expansion. Obviously, most of that goes toward the 9000-entry word list, to verify that your moves are valid. There wasn’t much left for the game itself!
Download and enjoy! https://github.com/Chysn/VIC20-20RDLE/tree/main/vic
Re: 20RDLE
Done. I'm studying
Bookmarked your Github;)
Thanks
Thanks
Re: 20RDLE
I didn't know the game.
Nice!
Nice!
Re: 20RDLE
Oh, yeah, you can't escape it.orion70 wrote: ↑Tue Feb 01, 2022 2:08 am Seems like this game is very popular...![]()
https://nypost.com/2022/01/31/new-york- ... n-figures/
The usual development task of "cloning" such a game isn't terribly interesting, because its logic is simple. What interested me here was storage and search on a VIC-20-sized platform. The rule is that you must play a valid word each move, and there are 8938 5-letter words in the U.S. English Scrabble dictionary, and 27.5K of memory available. You can't just try to jam 8938 x 5 bytes into memory. First, I'm storing each letter in five bits instead of 8, so letters need to be stored across byte boundaries. But this wasn't enough, because (9K x 5 letters x 5 bits)/8 bits is still almost exactly as much a +24K VIC has. So the words are alphabetized, with only the last four letters stored in three bytes, and there's a 52-byte table that keeps track of the starting offset of each letter. This gets a 9000-entry word list down to just over 26K.
One bit of each 3-byte packet is used as a starting letter boundary, an easy way to stop the search. Another bit is used to mark the 3000 most-common words, which can be selected as the puzzle.
Re: 20RDLE
Good effort - nice to see the Vic keeping up with the times...
I've been playing the C64 online version.
Something very nostalgic about connecting up to a BBS with a C64 and CRT monitor from my garage man-cave.
https://youtu.be/rDlWmLjZ4vY?t=26
https://misterfpga.org/viewtopic.php?t=3954
Re: 20RDLE
chysn wrote: ↑Tue Feb 01, 2022 8:52 am You can't just try to jam 8938 x 5 bytes into memory. First, I'm storing each letter in five bits instead of 8, so letters need to be stored across byte boundaries. But this wasn't enough, because (9K x 5 letters x 5 bits)/8 bits is still almost exactly as much a +24K VIC has. So the words are alphabetized, with only the last four letters stored in three bytes, and there's a 52-byte table that keeps track of the starting offset of each letter. This gets a 9000-entry word list down to just over 26K.
Really very smart. I'm trying to understand the logic, it's not easy.
Re: 20RDLE
Interesting, this seems like a simplified version of Deterministic acyclic finite state automatonchysn wrote: ↑Tue Feb 01, 2022 8:52 am You can't just try to jam 8938 x 5 bytes into memory. First, I'm storing each letter in five bits instead of 8, so letters need to be stored across byte boundaries. But this wasn't enough, because (9K x 5 letters x 5 bits)/8 bits is still almost exactly as much a +24K VIC has. So the words are alphabetized, with only the last four letters stored in three bytes, and there's a 52-byte table that keeps track of the starting offset of each letter. This gets a 9000-entry word list down to just over 26K.
I guess you could reduce it even further by building a full tree, but in this case you didn't need the additional lookup complexity?
Re: 20RDLE
That looks like a cool thing, thanks for the link! I'll check that out in detail later today.beamrider wrote: ↑Wed Feb 02, 2022 4:19 am Interesting, this seems like a simplified version of Deterministic acyclic finite state automaton
I think I might have had some memory savings doing a tree for the first two characters, certainly not more than that. If the letter table isn't complete (that is, 26 two-byte offsets), then a third byte per letter must be used to identify the letter. This eats up the savings of the letter being implicit in the index. But a second-level index would use 1352 bytes, plus 9000 x 2 (2 bytes to store three letters), so a significant savings over a one-letter index. The code complexity would have gone up a bit, though. If I had needed to store an extra, say, 3000 words, I would have had to do this.I guess you could reduce it even further by building a full tree, but in this case you didn't need the additional lookup complexity?
- mathom
Re: 20RDLE
So I had heard of this game but never played it until I found a couple of VIC versions. First I noticed this on YouTube
https://www.youtube.com/watch?v=-1dE0U3vviQ by Matt Heffernan. It plays well but is "hard" to load because of having to load a two-part cartridge image.Then I remembered that you had posted one so I gave it a try. It is an enjoyable and moderately addictive game. I like your screen layout and the border color change on "not a word" and of course it is easier to load. So much for the "honeydo" list for the rest of today.
...mathom...
