Vic GUI
I just downloaded the (mockup) VIC screenshot of Elite, and now this VEOS or something - and it's already working! Thanks for this, I can't wait to show VIC windows to my friends :D .
Kananga
Post by Kananga »
orion70 wrote:I just downloaded the (mockup) VIC screenshot of Elite, and now this VEOS or something - and it's already working! Thanks for this, I can't wait to show VIC windows to my friends :D .
Actually, the (mockup) Elite screen would fit into a window of the GUI ;-)
KingTrode
Post by KingTrode »
Just downloaded the latest update:-
Wow - this project has come on quite a bit in such a short time, I'm very impressed indeed.
Keep up the good work Kananga :D
TBCVIC
Post by TBCVIC »
It would be fun and I guess possible to atleast make a working version of Pong for example, running in one window :)
Ola Andersson
Post by Vic20-Ian »
Fantastic, look forward to moving the windows around and to having focus return to last window after closing one.
Kananga
Post by Kananga »
Vic20-Ian wrote:Fantastic, look forward to moving the windows around and to having focus return to last window after closing one.
The program could activate the new top-most window after destroying a window, which is quite easy to implement. It would imply when you select something from the menu window, which opens a new window:
1 - menu window closes
2 - new top-most window is activated and redrawn
3 - frame is hidden again if the new frame needs its character memory
4 - new frame shows up
ATM, I am not sure if the extra steps (2&3) would be too annoying and how to avoid them in a general way. Perhaps a flag that is set when closing a frame and reset when a new frame is created. The main loop could check that flag and activate the top-most frame, if that flag is set.
I feel like I'm only seeing the top left corner of a larger desktop. Are my settings wrong? Can someone post a screen shot?
KingTrode
Post by KingTrode »
Jeff-20 wrote:I feel like I'm only seeing the top left corner of a larger desktop. Are my settings wrong? Can someone post a screen shot?
This a screenshot from WINVice:-
Jeff, try setting VICE to PAL.
Boray
Musical Smurf
Post by Boray »
KingTrode wrote: This a screenshot from WINVice:-
http://sleepingelephant.com/ipw-web/bul ... php?t=4413
D'oh. I just had PAL emulation on, but I forgot to check VIDEO STANDARD to make sure it was PAL too. Fixed now. Thanks.
Now I can't seem to pull up the task manager window... :wink:
saehn
Post by saehn »
Jeff-20 wrote:D'oh. I just had PAL emulation on, but I forgot to check VIDEO STANDARD to make sure it was PAL too. Fixed now. Thanks.
PAL Emulation is just a display filter, BTW. It's kind of similar to the scanlines setting in that it alters the way the emulated C64 output looks. It doesn't affect any of the system timings, however. You can have VICE set to a Video Standard of NTSC and still turn on PAL Emulation.
Nevermind if you already knew that. :-)
Kananga
Post by Kananga »
Jeff-20 wrote:Now I can't seem to pull up the task manager window... :wink:
No tasks to manage yet, but you may get a blue screen... :P
nbla000
Salmon Run
Post by nbla000 »
wow, very good progress !!!
Kananga
Post by Kananga »
I have added NTSC support (24x30, probably too big) and screen refresh sync.
Would be great if somebody with access to an NTSC-Vic could test it:
http://vin20.googlecode.com/files/vin-0.2.prg
