*SOLD OUT* 32k RAM expansions for the VIC-20 - 25$ each
Vic 20 Item Exchange
Only 6 left!
unchained1984
Thanks FRancois
Post by unchained1984 »
Just wanted to say a big thank you to Francois for shipping one of his 32k expansion carts over to Scotland, works very well indeed. Also a true gentleman.
Re: Thanks FRancois
unchained1984 wrote:Just wanted to say a big thank you to Francois for shipping one of his 32k expansion carts over to Scotland, works very well indeed. Also a true gentleman.
Thank you very much for the positive comment!
I'm glad you enjoy!
If I may suggest, try the expander with a few of Ghislain's wonderful 32k games.
unchained1984
The suggestion is very much appreciated Francois, I'll do just that.
kind regards,
Sandy
Sid1968
Post by Sid1968 »
I want to have one. Please tell me how to pay it.
Regards
Sid
Sid1968 wrote:I want to have one. Please tell me how to pay it.
Regards
Sid
PM sent!
Only 5 left!
Only 4 left!
Only 3 left!
akator
Post by akator »
eslapion wrote:Only 3 left!
PM sent :)
akator wrote:PM sent :)
Last one left!
SOLD OUT!
Thank you all!
sjgray
Post by sjgray »
eslapion wrote:The 32k expansion also has a ROM socket to add extra ROM options such as VICMON, Programmer's Aid and Super Expander.
I got my expander and it's working great. I'm interested in perhaps adding BASIC4. I admit I'm a little rusty in VIC-20 technical details. Just to clarify does the expansion board accept EPROMS or regular ROMS? What are the extra jumper/switches for? Are they documented anywhere? Will there be any problems installing a socket for the ROM/EPROM?
Thanks!
Steve
sjgray wrote:I got my expander and it's working great. I'm interested in perhaps adding BASIC4. I admit I'm a little rusty in VIC-20 technical details. Just to clarify does the expansion board accept EPROMS or regular ROMS?
The pinout for ROMs or EPROMS is generally the same so your question only makes sense if you specify which type of chip you intend to use specifically.
The Ultimate Expander was designed to be compatible with (EP)ROMs of a capacity of 16k x 8 or 32k x 8 with parallel access. These include 27128, 27256, 23128, 23256, 27C128, 27C256 and 27128B.
The 2 DPDT switches control wether BLK 3 and BLK 5 give you access to the RAM expansion or to the (EP)ROM content.
The last switch to the right is for 32k x 8 (EP)ROMs only and toggles between the lower and upper half of the chip being presented to the VIC. A pair of 1N6263 diodes will also be necessary if you intend to use a 32k x 8 (EP)ROM.
If you know how the VIC memory map works, no documentation should be necessary.
The board was specifically designed to accept a 28 pin DIP 0.6" wide socket. A socket is recommended if you eventually want to change the content of your (EP)ROM without the need to desolder.
sjgray
Post by sjgray »
Well, most VIC and C64 cartridges use masked 8K roms which are definitely NOT pin compatible with most 8K EPROMS.
eslapion wrote: The Ultimate Expander was designed to be compatible with (EP)ROMs of a capacity of 16k x 8 or 32k x 8 with parallel access. These include 27128, 27256, 23128, 23256, 27C128, 27C256 and 27128B.
So these are fairly large compared to normal carts. I was assuming perhaps one 8K ROM or EPROM would fit there.
Like I said.. I don't really.
eslapion wrote: The board was specifically designed to accept a 28 pin DIP 0.6" wide socket. A socket is recommended if you eventually want to change the content of your (EP)ROM without the need to desolder.
Sure, a socket is nice. I was thinking more of clearance... The board is really tight to the case.
Thanks for the info.
Steve
