zippy - yet another serial fastloader
Re: zippy - yet another serial fastloader
Mike wrote: Sun Oct 13, 2024 8:45 am It's in line to your proposal, but please check my preceding post why it could be a good idea to simply keep the BCC loop instead.
I think our posts crossed, if you abort the close the new behaviour still completely clears the file table. You don't get a second chance.
srowe wrote:I think our posts crossed, [...]
That's why I asked you to take my post one further up into consideration. :wink:
[...] if you abort the close the new behaviour still completely clears the file table. You don't get a second chance.
With your implementation, yes. It's an equally valid approach to handle the situation, yet still needs to be documented (TBH - seeing that prompt to press record upon CLR/RUN/edit has a good potential to surprise people).
Mike wrote: Sun Oct 13, 2024 9:44 am
srowe wrote:[...] if you abort the close the new behaviour still completely clears the file table. You don't get a second chance.
OK, I've gone with your suggestion and terminate the loop if there's an error, it keeps the code simple. I would expect the new option to be used within an application rather than with BASIC, otherwise the change in behaviour is going to cause confusion as you note.
