You have to replace stems by unscrewing the back of the keyboard, they're a single piece.
Project VIC
Re: Project VIC
Re: Project VIC
Huh. This is damn peculiar...
Right now, I kind of suspect a 6522, but I'm going to look into this a bit further. This is the same VIC-20 that I picked up and (mostly) got working last spring. Results from VIA 1 timer 1 were likewise only at the extremes.
And okay, right now the same program is producing credible results. The plot thickens.
Update: RND(X) seems to work when X > 0. PRG says that "X=0 generates a random number from a free running clock." I haven't looked into this yet, but I'll be that "free running clock" is VIA 1 Timer 1, which doesn't count down; it just alternates between 0000 and FFFF on this machine.
Re: Project VIC
RND(0) uses VIA1 timers, which are also used for RS-232 timing. Can you test that on this VIC?
Re: Project VIC
Hey! Yeah, I was just making an update as you were writing this. The VIA timer issue is something I noticed last week. But my reasoning at that time was, "If there's something wrong with a VIA timer, the failure would be more catastrophic." Apparently VIA 1 Timer 1 isn't super-critical. I don't do anything with RS-232, though.
The VIA might have been failing a year ago. Or I could have killed it when I was doing my early user port experiments. Either way, I think I first try a new 6522?
Re: Project VIC
Unfortunately, while VIA#2 is socketed, VIA#1 is not. I’ve practiced a lot of chip removal on a dead C64, and I’m pretty confident with desoldering. But I do not look forward to the time it will take.srowe wrote: ↑ If they're socketed you could try a replacement or just swap them around.
Obviously, I’ll install a socket while I’m at it.
