Hi eslapion and levoman,
WOW!
That's impressive at what you've achieved levoman. I'm out of my depth here. I'm trying to follow along as best as I can
I am keen to know more!
eslapion wrote: ↑Fri May 15, 2020 4:36 pm
The trigger should always be at TTL level or about 1.3-1.5v.
That's a good piece of information with the results I am looking at in this folllowing video I made regarding the Winbond W27c512 EEPROM.
Personally from an oscilloscope perspective I love the the Winbond W27c512 EEPROM. It produces some outstanding compelling visual results.
The C64 board I'm using is a ku-14194hb it has been unaltered is so far as identical replacements of electrolytic capacitors that had leaked and failed. As far as I can tell no alterations were done to the board before it came to me.
Apologies for the rough video. There are a few errors . I quoted pin 13 of the PLA when in fact it is pin10, I miss quoted the oscilloscopes number to mention a few.
Please let me know if I have made mistakes in the testing methodology. I can quite easily go back and retest with the correct method....
https://youtu.be/GA0RS2sTuUw
I did note these following results are taken with the oscilloscope talking readings from a powered off to powered on C64.....
OTP PROM marked CHINA the RMS voltage on pin 10 is around 240mV (I did notice that this chip did not trigger eslapion's glitch tester on startup- this is a significant observation)
Commodore Factory PLA RMS voltage on pin 10 is around 3.5V
The Ultimate PLA RMS voltage on pin 10 is around 3.75V
Original ST PLA (From electronics shop) RMS voltage on pin 10 is around 3.5V
Texas instruments UV EPROM PLA RMS voltage on pin 10 is around 4.5V
Winbond w27c512 PLA RMS voltage on pin 10 is around 4.5V
I am not sure on these RMS voltage readings. I think the big RMS voltage reading is a fact that the oscilloscope is taking the values of an off C64 to an on C64. Someone may be able to shed some light on this issue.
