Octal numbers are used in the chmod command in Un*x. In former times there were machines with 6-bit bytes (as the CDC's), where 2-digit octal numbers "naturally" fit into.
And, to get back to:
[...]decimal equivalence of $7CBA?[...]
I just could ask, what is the hexadecimal equivalence of 1048576? $100000, of course! One should use that number system, where the numbers are expressed in the easiest way. The choice between Hex and Binary is then only a matter of convenience, with Hex grouping 4 (itself a power of 2!) binary digits into one.
Tip - Get a calculator that can use HEX, BIN etc!
- Schema
- factor
Btw, Hesmon can convert between HEX and DEC and also add and subtract HEX values...
/Anders
/Anders
Besides HEX, BIN, DEC and OCT, my calculator can also use PEN (base 5). Have you ever heard of a use for that?
/Anders
/Anders
