FE3 Software Collection
Re: FE3 Software Collection
I want to add my thanks for this being released to the general public. I always look forward to these updates. Makes life a lot easier to play with the Vic when I get the spare time to do so
Ops Ops (pun intended ), I cannot load Darwin's adventures. When I try to load, it gives either a Load error or a Syntax error (see pics). Everything else but things in this folder seems to load OK, even if I tried only a fraction of your collection.
I'm not able to fiddle with LOADER files, so I kindly ask if anyone can correct this for me. TIA
Works for me. Which version of the collection you have?
FE3-software-collection_2021-04-04
@srowe: If you still have the old SD2IEC FW, could you test this too?
@orion70: Which version your SD2IEC has?
Start VIC-20 with wedge enabled and enter to reset drive and then to query result.
@UI
73,SD2IEC V0.9.0,00,00
I recommend to upgrade SD2IEC firmware. I guess older versions handle long filenames differently.
Thank you. I downloaded the latest binaries (zipped) from sd2iec.de. It contains several files:
Which is the right one for the FE4? IIRC, other SD2IEC devices simply upgrade it upon turning the VIC on. Is it the same for the FE4, or a specific program should be used to upgrade the firmware?
TIA.
TIA.
Usually you just put all the binaries in the root-dir of the SD-card and when turning the SD2IEC on it will automatically update and pick the right update file out of the bunch.
