My son made this video about a theoretical One-Instruction Set Computer architecture called SUBLEQ. I'll let him describe the theory and this specific implementation. Then come back here when you're done... https://www.youtube.com/watch?v=FvwcRaE9yxc
The single instruction for SUBLEQ is:
subleq a,b,c
In 6502 assembly, this instruction can be synthesized as follows:
i0: lda b
sec
sbc a
sta b
bcc br
bne i1
br: jmp c
i1: etc...
subleq a, Z
subleq Z, b
subleq Z, Z
This evening, after watching my son's video, I wrote a SUBLEQ compiler for the VIC-20 as a wAx plug-in. The syntax for a SUBLEQ instruction in this system is
'addr aaaa bbbb cccc
Here's the data setup, code, run, and result check of the addition program:
And here's the disassembly of the SUBLEQ addition program in 6502:
Here's the wAx plug-in code:
; SUBLEQ compiler plug-in for wAx
; 'addr aaaa bbbb cccc
; Where addr is the compile target address
; aaaa is the address of A
; bbbb is the address of B
; cccc is the address of C
; Subtract A from B
; Store result in B
; Branch if B is less than or equal to zero
; References:
; https://en.wikipedia.org/wiki/One-instruction_set_computer
; #Subtract_and_branch_if_less_than_or_equal_to_zero
; https://www.youtube.com/watch?v=FvwcRaE9yxc&t=142s
; wAx API used in this plug-in
EFADDR = $a6 ; effective address
X_PC = $03 ; External persistent counter
Buff2Byte = $7000 ; Get 8-bit hex number from input buffer to A
CharOut = $7006 ; Write character in A to output buffer
IncPC = $700f ; Increment persistent counter
ResetOut = $701b ; Reset output buffer index
EAtoPC = $7024 ; Copy effective address to persistent counter
ShowPC = $7021 ; Write persistent counter to output buffer
Store = $0247 ; Plug-in storage (8 bytes)
OUTBUFFER = $0218 ; Output buffer (24 bytes)
* = $033c
Main: bcc subleq_r
ldy #$00
-loop: jsr EAtoPC
jsr Buff2Byte ; Get six hex bytes: aaaa bbbb cccc
bcc add_rts
sta Store,y
iny
cpy #$06
bne loop
ldy #$00
-loop: lda SubleqCode,y
cmp #$f0 ; Bytes of $f0 and up are interpolated
bcc go_on
and #$0f ; Put the index of the SUBLEQ operand
tax ; pointer in X
lda Store,x ; Get the data for the SUBLEQ instruction
go_on: sta (EFADDR),y ; Store the instruction in memory
iny ; Get the next instruction from the table
cpy #$11 ; until done
bne loop ; ,,
; After the SUBLEQ code is generated, show a prompt for the next instruction
jsr EAtoPC ; Update persistent counter
tya ; $11
clc ; Add 17 to PC for next address prompt
adc X_PC ; ,,
sta X_PC ; ,,
bcc prompt ; ,,
inc X_PC+1 ; ,,
prompt: jsr ResetOut ; Reset output buffer
lda #"'" ; Show the plug-in character
jsr CharOut ; ,,
jsr ShowPC ; Show the next address
lda #" " ; Then a space
jsr CharOut ; ,,
ldy #$00 ; Transfer everything to the keyboard
-loop: lda OUTBUFFER,y ; buffer
sta $0277,y ; ,,
iny ; ,,
cpy #$06 ; ,, (6 characters = "'addr ")
bne loop ; ,,
sty $ad ; Store prompt in keyboard buffer
add_rts: ldy #$00 ; Add an RTS if the next instruction isn't
lda (X_PC),y ; LDA. If the next instruction IS LDA,
cmp #$c8 ; then this compiler assumes that the
beq subleq_r ; current session is a patch of existing
lda #$60 ; code, and leaves the LDA alone
sta (X_PC),y ; Add RTS to end of program
jsr IncPC ; Increment counter
subleq_r: rts
; This is the 6502 representation of a SUBLEQ instruction
; Bytes with high nybble $f are interpolated using the low
; nybble as the index to Store, with
; $f1,$f0 = A
; $f3,$f2 = B
; $f5,$f4 = C
SubleqCode: .byte $ad,$f3,$f2 ; i0 lda b
.byte $38 ; sec
.byte $ed,$f1,$f0 ; sbc a
.byte $8d,$f3,$f2 ; sta b
.byte $90,$02 ; bcc br
.byte $d0,$03 ; bne i1
.byte $4c,$f5,$f4 ; br jmp c
