Vic 20 worked for seconds then distorted screen
asapreta
Occupation: Hobbist
Post by asapreta »
Hi guys.
I just received my first Vic 20 and when I powered it on I was able to see the "boot" screen, with about 4kb free and typed some keys to test the keyboard then the screen distorted like the picture below:
I am using the built PSU I use for my c64's with no problems on them.
As it is my first Vic20 I don't know where to start to look for the problem.
Thanks for any advice.
Re: Vic 20 worked for seconds then distorted screen
I'd suspect a problem with the clock generator if this was a C64. Probably similar with a VIC :)
asapreta
Occupation: Hobbist
Post by asapreta »
groepaz wrote: Tue Jun 30, 2020 2:25 pm I'd suspect a problem with the clock generator if this was a C64. Probably similar with a VIC :)
You may be right.
I will see if I find a M53202P or similar here.
I'd suspect the TTL 7402 isn't the same, right?
asapreta
Occupation: Hobbist
Post by asapreta »
Tested the 7402 and the Crystal and both are fine.
Most likely to be the VIC chip, you probably don't have a spare to swap it out?
asapreta
Occupation: Hobbist
Post by asapreta »
srowe wrote: Thu Jul 02, 2020 6:42 am Most likely to be the VIC chip, you probably don't have a spare to swap it out?
I was wondering about it too. But no, I don't have one. It is my first VIC-20 and it just worked for seconds.
