Has anyone got a disk dump of Rockman?
oracle_jedi
Post by oracle_jedi »
I've looked around for this one, and only found TAP images.
I did find a .PRG copy, but it doesnt have the graphics initialized and crashes after a few seconds.
Re: Has anyone got a disk dump of Rockman?
Never was released on disk (there's about two games from back in the day I've seen on disk!), it was tape only.
oracle_jedi
Dumped to disk and fixed for NTSC.
Rockman (1984)(Mastertronic)[unex].zip
(5.51 KiB) Downloaded 196 times
cbm-warrior
Post by cbm-warrior »
Good job, @oracle_jedi ... you can also R.I.P. The Game for disk? Is it the predecessor program from the same author and with the same copy protection (?)
Miklós
Occupation: butcher
Post by Miklós »
Hi
ROCKMAN Discfix , detect NTSC/PAL
+ easy trainer (y/n)
live, time
ROCKMAN 1file => run on 8k or higher.
R.I.P+ Rest in peace+ 1file => run on 8k or higher.
Please search for: c NOV 01.zip
file.
viewtopic.php?f=10&t=797&p=111007#p111007
oracle_jedi
cbm-warrior wrote: Mon Feb 17, 2020 3:41 am Good job, @oracle_jedi ... you can also R.I.P. The Game for disk? Is it the predecessor program from the same author and with the same copy protection (?)
@cbm-warrior
Attached is a revised disk image with Rockman and RIP on it. Both fixed for disk and with NTSC support as well.
Rockman and RIP (1984)(Mastertronic)[unex].zip
(8.46 KiB) Downloaded 148 times
oracle_jedi
Miklós wrote: Fri Mar 06, 2020 6:52 am
I see RIP.BIN just that, "demo, intro, trial"
you need to rip the $ 0200- $ 0380 mem. not enough 1000-1e00. unexp Vic 20
There are two files: RIP and RIP.BIN. I put it on the same disk image as Rockman as @cbm-warrior asked for it in this thread, and noted it was the predecessor to Rockman.
RIP is a modified version of the cassette loader, it makes a jump to $1644 which moves memory to locations $02a1, $0117 and $1dff, and then loads the RIP.BIN file, with a jump to $1400.
It works fine on VICE, is there something not working for you?
Miklós
Occupation: butcher
Post by Miklós »
Hi all.
Rockman+2
R.I.P.+
file.
oracle_jedi
Miklós wrote: Fri Mar 06, 2020 5:35 pm
Angol
Please just try what you can do, I see something.
followed by ROCKMAN + 2 in the RM2 GAME game.
So I renamed it RM.BIN and it looks like seers out of it.
I have absolutely no idea what you are talking about, nor any idea who Angol is.
