I have a couple of questions about use of the zero page memory.
I was reading Mapping the Vic and it states two memory ranges are used either by BASIC or the Kernal -
$00 - $8f = BASIC working storage
$90 - $ff = Kernal working storage (mostly)
After a machine code program has loaded from tape or disk and is running, or the equivalent for a cartridge, do you know if the BASIC working storage (up to $8f) is safe to use if I am not intending to return to BASIC or use features of BASIC?
I've not looked at loading from tape or disk in my program yet, would this require use of this area of memory?
Question on use of zero page addresses
- AndyH
- Occupation: Developer
- AndyH
Re: Question on use of zero page addresses
I should add that I wrote a program to clear $00 to $ff and then do some general stuff and watched what happened in VICE and <$8f appeared to remain untouched.
Am I opening up a world of pain for myself?![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
Thats pretty much what i would do as well
most of the zeropage is free if you dont use BASIC at all, you'll need a few locations if you still want to use KERNAL. what exactly you can use depends on which functions you want to use exactly.
![Smile :)](./images/smilies/icon_smile.gif)
V-FORTH uses all of zero page below $90 and then uses KERNAL calls for all its I/O.
Hi, Andy,
a posting of mine in an older thread confirms the partition of zeropage between BASIC ($00..$8F) and KERNAL ($90..$FA). As has been pointed out already, $FB..$FE are free. $FF gets overwritten during float -> ASCII conversions (and thus effectively 'belongs' to BASIC).
If you write something that could be in the widest sense be regarded as "language", i.e. it 'replaces' BASIC as user interface and doesn't call any of the routines in the BASIC interpreter in $C000 .. $E47F, then $00..$8F are free for your use. What re-inforces this assessment is - even though the BASIC interpreter calls KERNAL routines to perform some of its work, the KERNAL in turn *never* calls routines in the BASIC interpreter - with two exceptions: cold start (after reset, vectored through $C000) and warm start (after STOP/RESTORE, vectored through $C002). You can thus be sure, that no KERNAL call does change/use BASIC zeropage locations (neither directly nor indirectly).
For something that's supposed to go alongside BASIC, yet still needs some more zeropage, the addresses shared between tape and RS232 operation are useful candidates. Details see here.
In said thread, the OP did likewise. However (see my response there), you can't really expect that the ROM code still shows the same behaviour regarding zeropage usage, when you overwrite most of its workspace.AndyH wrote:I should add that I wrote a program to clear $00 to $ff and then do some general stuff and watched what happened in VICE and <$8f appeared to remain untouched.
- AndyH
Many thanks - answering everything I need and puts my mind at rest. Loads to read up on.
I did trigger a flashing cursor in the top left by setting the kernal space to 0!
