Is there a SYS to perform a run/stop-restore? There doesn't seem to be a RESTORE button on the vic20-emulator on Amiga, so I would need a SYS to do the same thing as the button combination. (By first pressing break and then typing in the SYS manually)... Anyone?
/Anders
In theory, I believe the BRK instruction (op-code 00) will cause a NMI interrupt just like pressing the RESTORE key will do. SYS 65234 should cause a Basic Warm Start, which occurs when a BRK is reached.
See also the document http://www.ftp.funet.fi/pub/cbm/documen ... c20rom.doc and similar ones (C64 may do too) for other hints.
SYS 58471 supposedly warm-starts Basic without clearing the screen like the other one above, but you really want it to appear like you hit RUN/STOP + RESTORE?
