You can get a tenner off the Penultimate+ cartridge at the moment, using code WHONEEDSSPRITES at check out
Linky: https://www.thefuturewas8bit.com/shop/c ... -plus.html
Code has limited uses, one per customer.. and all that jazz
I don't necessarily see that as greatly beneficial. Having both C64s and VIC-20s, I would see it as a burden to have to turn on my VIC-20 to be able to use the SD2IEC on my C64.mingle wrote:If only they would integrate an SD2IEC device into the cart (would that be a difficult task?), it would be even more of a 'must-have'...
That's why I built 4 SDIECs, one each for the VIC, C64, C128 and Plus4. I built the 4 with home-made PCBs for the cost of purchasing just one online and used the 3d printer for the cases. No unplugging and swapping needed.eslapion wrote:I don't necessarily see that as greatly beneficial. Having both C64s and VIC-20s, I would see it as a burden to have to turn on my VIC-20 to be able to use the SD2IEC on my C64.mingle wrote:If only they would integrate an SD2IEC device into the cart (would that be a difficult task?), it would be even more of a 'must-have'...
However, it would be great to be able to plug in both computers into the same SD2IEC at the same time.
I also have a C128 but I don't use it often.
that's my dream that someone will make Xbox-Live for the Vic... no takers so farjoshuadenmark wrote:Or wifi with a constant updated vic 20 library online
