User Port Pins
cbmeeks
Website: http://meeks.co
Occupation: Code Monkey
User Port Pins
Post by cbmeeks »
I posted this over on comp.sys.cbm so sorry for the cross-post.
I'm curious about how to access certain pins of the C64 User Port. Going by the pinout here:
https://www.c64-wiki.com/wiki/User_Port
I see there are some pins I'm not familiar with.
4       CNT1       Counter 1, from CIA #1
5       SP1        Serial Port 1, from CIA #1
6       CNT2       Counter 2, from CIA #2
7       SP2        Serial port 2, from CIA #2
8       /PC2       Handshaking line, from CIA #2
9       ATN        Serial attention in
B       /FLAG2     Flag 2
M       PA2        PA2
I have a basic idea what the counters are for but I'm looking for more detailed information on all of those pins.
Are there any programming and/or schematics out there that indicate how to use them in various projects?
Thanks
Cat; the other white meat.
Re: User Port Pins
A sharp look into the schematics of VIC-20 and C64 is surely instructive to clear this up.
You have some pins connected to the +5 VDC and 9 VAC supply voltage, and there's also a /RESET signal line. For the "TTL level" RS232 as implemented by the KERNAL, both computers use a defined set of the port pins and handshake lines to connect to the other end (be it another computer, terminal, printer, modem, whatever).
Other than that, it's a *user* port: you can use the user port edge connector as equivalent to the port pins of the respective VIA or CIA chip. That means, in any way you want - you just have to honour those are TTL/NMOS signals, capable of driving only a certain type of load. Certain hardware drive speeders use this to implement an 8-bit-parallel protocol with the disk drive. For another example, I use 4 of those port bits to provide an extra 4 address lines for the banked colour RAM of my VFLI mod.
That one was much easier done than adding another dedicated chip with an own I/O port.
