penultimate WTF !??
penultimate WTF !??
Hello
i have ordered a Penultimate directly from thefuturwas8bits.com
i have received the cartridge two days ago, and it do not work at all.... tested on two working Vic, one was arrived from revision the same days !
the two button are only doing a reset, the memory count is still 3.5kb.
so i have send a mail to the seller, two days ago, no answer......
is Thefuturwas8bits is a serious stuff ??
i start to have doubt
Laurent
Laurent
- taborj
- Website: http://obsolete.site
Re: penultimate WTF !??
Did you contact them? Perhaps you just got a dud. It happens, I'm sure.
yes i have contact them two timer since two days... no reply
Laurent
Laurent
Do other cartridges work? Sometimes corrosion or dirt on the cartridge socket can make an unreliable contact.
hi
yes i have a 16kb vixen cart who work fineon both my vic
the PU havework one time in two hours of connector cleaning
think the PU is deffect
cheers
Laurent
cheers
Laurent
- cbmeeks
- Website: http://meeks.co
- Occupation: Code Monkey
Well, remember that these hobby projects are usually run by one person and not some large company. So "customer support" has to take a back seat to things like family duties, work, etc.
I'm not defending the guy, just saying. Two days may not be enough time. I would give him a few more days and make sure you have his email correct or the correct way to contact him.
Now, having said that, I've been reading things like this for a long time. Not just VIC-20 stuff, but lots of places. For example, I bought an SGM at AtariAge and paid a little more than $100 USD. Took almost a YEAR for me to get it. I expected 3-4 months but not a year.
Anyway, I understand your frustration. The makers/sellers do this for the passion. Not the profit. I do wish, however, that the ones selling >$50 devices would be more transparent and responsive at times. It's hard for me to shell out $100 for something and not get any feedback.
Cat; the other white meat.
- amigo-mexicano
- Website: http://www.video-juegos.com
- Occupation: IT Guy
Did they answer you yet?
i have returned the cart, it 'll be tested
but i have already done a lots of test, i have test all continuity between cartridge PCB and expansion port soldering on the motherboard
so, i do not have any connector issue....
to be continue
cheers
Laurent
to be continue
cheers
Laurent
Hi
I have received my cart, repaired, seem the prom was fryed....
So , i plug it in my vic20, power up and, nothing.... start on a 3.5k config without any menu......
I have tryed it on 6 Vic20 !!!! nothing
Sent a mail to the seller (TFW8bits), and told me
"your Vic20 have fryed the cart again"
How can it be possible ? i use a 32K expansion without any trouble !!!
I have check my PSU voltages, it's ok, the internal voltage, and it's ok again
I do not understand.....
any idea ?
Laurent
any idea ?
Laurent
If EPROMs are X-Rayed during shipment it can cause issues with them. But that is a long shot.
-Autobiography of Mark Twain
Hi
it's exactly the issue of my PU, the prom was fryed.
i 'll ask if they can ship me another prom
Laurent
Laurent
i have sent back the PU, i'll be refunded without hope to use a PU a day....
sad.....
Laurent
sad.....
Laurent
