Cartridge designs released - Eagle PCBs
Re: Cartridge designs released - Eagle PCBs
Okay, I just ordered up a protopack of boards. I think I will get a few sockets and make a couple dev boards for testing the eproms. If anyone has a link to a socket they would recommend please post it.
I have a truckload of machined pins 28 pins sockets I sell for 0.50$ each... PM me!toby405 wrote:Okay, I just ordered up a protopack of boards. I think I will get a few sockets and make a couple dev boards for testing the eproms. If anyone has a link to a socket they would recommend please post it.
These are the type I use https://www.ebay.com/itm/161282902870 but if you need them quick order from a USA seller. The machined ones that eslapion has are more durable for repeated use.
-Autobiography of Mark Twain
I'm getting them from eslapion but he doesn't have any capacitors.norm8332 wrote:The machined ones that eslapion has are more durable for repeated use.
How do these look?
https://www.ebay.com/itm/232524021393
Those will work fine.toby405 wrote:I'm getting them from eslapion but he doesn't have any capacitors.norm8332 wrote:The machined ones that eslapion has are more durable for repeated use.
How do these look?
- Website: https://restore-store.de
Nice work. I say thank you very much for these layouts. After Chinese New Year I will order some and think about to bring them into my small hobby shop to give people the chance to buy a single PCB or a DIY kit for small money and without having long lead time from China.
Hi guys,
I have ordered and finally received the pcb for 8k and 16k cartridges .
Although I am good in soldering I would like to ask some help for the programming part. I will start with the 8K board and a 27C64.
My question is :
- does the binary needs to be 8k or is this the maximum?
- which files can I use from the Vic20 Tosec? CRT and PRG can be used for a straightforward programming or do they need to be transformed into Binaries?
- Is there a link where to have a bunch of ready to program 8k (or less) binaries?
Thanks a lot
Rick
My question is :
Thanks a lot
Rick
Hi, all! I'd like to order the 8K two-panel cartridge PCB from PCBway, but they need a Gerber file instead of an Eagle file. Does anybody happen to have a Gerber file version of that?
Here it is. I haven't been on since 2020..it's been awhile. The PCBway will check them, if there are any issues just let me know.
- Vic8K-G_P1_gerb.zip
- Cart 8K P
- (188.27 KiB) Downloaded 51 times
Thank you! For the foreseeable future, I'm going to use MCes's JollyCarts, but I might order a run of these just for getting experience working with PCBway.
- JonBrawn
- Vic 20 Devotee
Also check with JLCPCB - they may be cheaper.
https://youtube.com/@vicenary
