Need help with FFD2 (CHROUT)
plbyrd
Website: http://thesharp.ninja
Occupation: Software Engineer
Post by plbyrd »
Has anyone ever encountered a situation where sending a value to FFD2 results in the wrong value being sent and with that wrong value returning in the Accumulator? If I do a READST immediately afterwards it returns $00
Re: Need help with FFD2 (CHROUT)
have you traced it to see if that is what actually happens? sounds like the problem is unrelated to ffd2 :)
What device are you sending it to?
plbyrd
Post by plbyrd »
srowe wrote:What device are you sending it to?
Rs232 on device 2
plbyrd
Post by plbyrd »
groepaz wrote:have you traced it to see if that is what actually happens? sounds like the problem is unrelated to ffd2 :)
Thank you for the tip. Stepping through FFD2 I found it is using $FA and I happen to use it too. So I adjusted my prg not to use FA and now it works!!!
