io expansion in vice?
Is it possible to set up the io expansion areas in vice for both pc and android versions?
Re: io expansion in vice?
Settings-Cartrdige/IO settings-Enable I/O-2RAM or Enable I/O-3 RAM
In the command line, you use the switches "+io2ram" and "+io3ram" to enable RAM in the respective areas.
Be aware though, that only a minority of users will have that kind of RAM expansion available on real h/w, if you plan on using this for own projects. More likely you will annoy quite a lot of MegaCart, FE3 and IEEE cartridge users if your programs thrash that scarce resource which should, IMO, only be used by cartridge firmware.
Thank you, I will deffinately keep that in mind.Mike wrote:In the command line, you use the switches "+io2ram" and "+io3ram" to enable RAM in the respective areas.
