Great Vic20 places on internet..
I miss two Vic20 internet pages a lot.. Those two were really great..
Armas Vic20 page:
http://members.fortunecity.com/timfy/vicimages.htm
Alhazred's VIC-20 page - Games Main Page
http://members.nbci.com/_XMCM/vic20/games.html
Now I can find screenshots only here..
http://www.digitpress.com/dpsightz/vic20
But I would like to find pics of gameboxes somewere too..
Armas Vic20 page:
Vic-20 video capture site...
Made some video captures before Mainframe 2003 and realised it could be valuable for people without access to a real Vic-20 so now it is all online. Horray?
http://www.gudinna.com/~zyz/vic20
Might get access to the recording studio some ohurs a month so requests for captures is possible. .. Sounds good? hmm tasty puppy... bluergh..
Or almost all, as some were added after this mirror was made. Maybe not cartridges, but other originally tape or disk based games. It reminds me that I have a few MB of commercial VIC-20 software previously not available for download on my hard drive. I once promised to upload it somewhere, but the anti-piracy story delayed the uploading.
Mikam, for the 8k ones... Just make sure you have 8K ram at block 5 ($A000). Then load the file ,8,1 and then sys 64802
LOAD "OMEGA RACE",8,1
SYS64802
If you have a Commodore 8K RAM cartridge, then you can open it up and find switches inside to use it for block 5.
Some games (some 8k and all 16k) requires two files to be loaded and that you have memory in two different blocks, for example block 3 and 5.
/Anders
SYS64802
/Anders
Hey, this is a great tip!!! I tested with VICE emulator and it works! Do you know if something like that is possible with a 16k expansion? I have an original Commodore 16k expansion and before attempting to open it...Boray wrote:Mikam, for the 8k ones... Just make sure you have 8K ram at block 5 ($A000). Then load the file ,8,1 and then sys 64802
And what about 4k roms? Any similar trick for those?
*Gabriele*
4k ROM files works just the same, just make sure you have RAM where they should be placed in memory.
I don't know how it is with the original 16K RAM cartridge, but I think my brother said once that they don't work for this... But I have a 16K RAM that is a rebuilt Commodore 8K RAM and it has switches for both 8K blocks letting me play any 16K plugins... My ram cartridge also has a read/write switch, letting me first load the game, then switch it to read only - and then I can even play games that has a ram testing copy protection.
All plugin imagnes I have on tape though (copied in the 80's) is actually positioned in block 3, so I had to do this before loading:
POKE43,0 : POKE 44,160
(Setting the basic memory to $a000).
They had probably made some adapter remapping cartridges to block 3 to be able to copy them without the game starting. Probably...
There might be ROM images that NOT are in the Commodores file format. (They should be 2 bytes smaller than commodore files), for example 8192 bytes instead of 8194), then you have to add two bytes to the beginning of the file to tell the vic20 where to load them into memory. (Before copying the files to the 1541). For a file that should be loaded into $a000, the first two bytes should be $00 and $A0, in other words, the address in reversed byte order.
/Anders
/Anders
I couldn't wait so I opened my 16k ram expansion. It's a german one and there are no switches inside. Instead I found (in the middle of the board, toward the front contacts) couples of soldering pads numbered 1,2,3,4,5.
Could it be there where a possible block switch could have been, maybe in a different issue of the board?
I wonder if shortening some of those pads would produce the desired result...
*Gabriele*
*Gabriele*
I wouldn't shorten anything if I didn't know for sure... Maybe you should both cut somewhere and shorten/solder something else... I don't know... One problem could also be that you maybe just have one big 16K hunk of memory, and how would you put 16K of memory in a 8K memory space? Block 5 is only 8K big...
You could look at a description of the expansion port and then trace the connections of the memory chips to see where in the memory space it mounts and where to change the connections. But the best is to ask someone who knows! I don't...
/Anders
/Anders
