There are tons of c64 Cartridge releases The Vic, however, has been severely neglected. So, if you have a game or utility that would make a great cartridge release, lets talk and see if we can get something out there!!
Thanks!
Wanted: projects to be released on Cartridge
Re: Wanted: projects to be released on Cartridge
hmm.. that sounds interesting. I have to finish my ZX spectrum game first, but new cartridge game release would be cool
Have to start to design something..
- Occupation: farmer
You are more than welcome to put WimBasic (from http://wimbasic.webs.com ) on a cartridge. Please let me know when you're downloading.
Regards,
Wim.
Regards,
Wim.
Wow! Wimbasic is pretty cool. I did make a cart of it and its really nice. Thank you for allowing us to do this!
I will make it available as an option on my RAM/ROM cart as well!
- joshuadenmark
- Big Mover
Is there a cart format of WimBasic for FE3 available?wimoos wrote:You are more than welcome to put WimBasic (from http://wimbasic.webs.com ) on a cartridge. Please let me know when you're downloading.
Regards,
Wim.
I don't know what special requirements there are to an FE3 cart format file, other than removing the first two bytes (the load address).
There is a wimbasic.cart file in the zip-file now that has that.
Regards,
Wim.
Regards,
Wim.
- joshuadenmark
- Big Mover
Thanks for your fast reply, will try this an give feedback if it runs on FE3
Sorry for the Hijacking
- Vic 20 Hobbyist
That was going to be my very first suggestion!! Wimbasic lol... Wimbasic with a ram expansion included would be the only thing cooler, although that might crank up the cost too high.
I was just thinking that Wimbasic is what the super expander should have been...like without "pseudo coordinates" for instance!!? You have a 1 in 5.7528089887640449438202247191011 chance of getting it correct! I remember reading that and FUMING. Just guess what pixel you're addressing! It's a game by itself!
Edit: We also have another addition to the language category, which could be a good cartridge! I would certainly buy both. The other is V-FORTH which srowe just completed.
No issue with MINIGRAFIK at even a slightly higher screen resolution of 160x192 pixels.Forbidden64 wrote:[...] what the super expander should have been...like without "pseudo coordinates" for instance!!? You have a 1 in 5.7528089887640449438202247191011 chance of getting it correct! I remember reading that and FUMING. Just guess what pixel you're addressing! It's a game by itself!
And we also had other good reasons to port VICtoria from SE to MG at that time.
