Hi,
I have a strange video artifact popping out randomly at power up for one Vic20.
Sometimes VIC prompt will look like this
A rapid recycling of the power switch will put back video to normal.
Any idea? Hope something is not failing in my VIC. I am using a video to SCART cable working good with a C64.
ViC20 strange behaviour at power up.
Re: ViC20 strange behaviour at power up.
This happens when the colour carrier frequency is outside the tolerance limits.
When your TFT isn't anymore able to sync to the colour phase, those psychedelic colours result - or an altogether b/w picture.
Please identify the mainboard revision (DIN or 2-prong PSU plug):
The fine adjustment of the oscillator is done by a capacitor trimmer in the vicinity of the VIC chip. On the 2-prong, this is C35 near to the quartz. On the DIN mainboard, this is C48. In most cases the VIC chip and the trimmer are located inside a metallic RF box.
Mark the old position of the trimmer or remember it. Normally, you'd need a non-metallic adjustment stylus, however while running the computer reacts to changes of the frequency quite often with a crash including black screen. Therefore, a normal screwdriver also does the service - while the VIC-20 is switched off. A quarter-turn at max in one of the two directions should suffice.
If you got it quite right, you have stable colours again. Do several trials in the warmed-up state to find the range where you have colour, finally set the trimmer into the middle of that range.
Hi,
It is the 2 prong version. The trimmer tweaking you are explaining as alteady been done (There are 2 plastic round trimmer one for video and one for black I believe) as I wasn't happy with the picture output. Anyway this strange artifact is still coming out from time to time. Maybe I need to trim again.
