VIC-20 Software Releases of 2016
Brazil
Occupation: sw developer
Post by Brazil »
Name: Péter és Pál
Author: Miklós Tihor & András Laczi
Released: 2016 january, original version written in 1985
Requirements: VIC20 with 3K expansion
Description: An action game for two person
Download: https://goo.gl/fqwFZO
Brazil
Winnetou
Post by Brazil »
Description: Jumping action game
Download: https://goo.gl/zKvPlA
Re: VIC-20 Software Releases of 2016
Author: tokra
Released: Feb, 1st, 2016 - March, 24th, 2016 for V2
Requirements: PAL VIC-20 unexpanded
Edit: Version 2 supports NTSC as well
Description: A VIC20-version of the browser-/mobile game of the same name. Just pick the lighter color. Sounds too easy, but isn't.
My entry for the Global Game Jam 2016. Done in under 48 hours at the University of Bremen Jam Site.
Download: http://www.tokra.de/vic/colorrun/colorrun-v2.zip (V2)
Discuss: http://www.sleepingelephant.com/ipw-web ... =10&t=7812
Author: tokra
Released: Feb, 24th, 2016
Requirements: PAL VIC-20 +24K RAM expansion
Description: A tool to split-up an MFLI-image into four FCB-images that can be edited with fcbpaint and which can then merged into a full MFLI-image again.
Download: http://www.tokra.de/vic/mfli-fcb-conver ... onvert.zip
Discuss: http://sleepingelephant.com/ipw-web/bul ... 59&p=85207
Author: Mike
Released: March 27rd, 2016 on Revision
Requirements: VIC-20 with +24K RAM expansion, Joystick (another +8K in BLK5 for SJLOAD)
Description: tile-matching board game
Download: mahjongg.zip
Read more and discuss Mah Jongg here.
Name: Game Theory (remake)
Author: Jeffrey Daniels
Released: April 2016
Requirements: Vic 20 with no expansion
Description: an all BASIC, one-button, Skinner box, Wariowarish game that uses either Keyboard (any key) or Joystick (fire button).
Screenshot: (?)
Download: http://www.sleepingelephant.com/denial/ ... ry-4.0.zip
Discuss: http://sleepingelephant.com/ipw-web/bul ... =10&t=7961
Neo-Rio
Post by Neo-Rio »
Author: Daniel Lawrence (PET original), Nathan Butcher (VIC-20 porting)
Released: April 13th, 2016
Description: Vic-20 port of the classic Role-Playing Game
Download: http://sleepingelephant.com/ipw-web/bul ... php?id=566
Fourm Thread here: http://sleepingelephant.com/ipw-web/bul ... =10&t=7946
Author: Mike
Released: May 22nd, 2016
Requirements: VIC-20 with +8K RAM expansion, Lightpen
Description: Lightpen drawing program
Download: minisketch.zip
Read more and discuss MINISKETCH here.
Name: Ultimem RAM-Expansion Chooser
Author: tokra
Released: May, 27th, 2016
Requirements: Ultimem-cartridge
Description: A RAM-Expansion Chooser-image for the Ultimem, so you can use it as a simple RAM-expansion for all your needs. Fastloader (SJLOAD) included.
Download:
ultimem-ram-sjload.zip
(2.26 KiB) Downloaded 781 times
Discuss and Installation Instructions: http://sleepingelephant.com/ipw-web/bul ... 470#p87463
Author: Simon Rowe
Released: June 2016
Requirements: VIC-20 with 8K in BLK5, VIC-1112 optional
Description: Extended BASIC with disk commands, works with both serial and IEEE-488 devices.
Download: http://eden.mose.org.uk/download/nubasic4.zip
Post by R'zo »
Name: Exit Plan Z
Author: Ryan Liston (R'zo)
Requirements: Vic-20, 16k expansion, joystick and a thirst for adventure.
Description: A zombie survival action micro rpg. Crawl through dark level after dark level of ravenous zs to escape a secret underground laboratory alive.
features
5 difficulty levels
Randomly generated levels
Multiple endings
Whack a Z battle system
d64+booklet (zip)-exit plan z 16k c=vic-20
d64-exit plan z 16k
(update) now at Zimmers-exit plan z 16k c=vic-20
discussion-exitplanz
majikeyric
Post by majikeyric »
Author: Majikeyric
Released: June 15, 2016
Requirements: VIC-20 with 32K RAM expansion
Description: adventure game
Screenshots:
Download the full package (D64, instructions, clues, plan, solution (in french)):
http://majikeyric.free.fr/my-itch/commo ... _vic20.zip
Read more and discuss Athanor here : viewtopic.php?f=10&t=8061
Post by R'zo »
Title: Micro Vicious
Author: R'zo (Ryan Liston)
Requirements: Unexpanded Vic-20, C=64 keyboard overlay(optional)
Description a monophonic synth that allows you to shift the tone, tune and the octaves of the vics 4 voices across 2 playable octaves.
download-Micro Vicious
discussion
Post by R'zo »
Title: Micro Vicious 2.0
Author: (R'zo) Ryan Liston
Language: Basic
Requirements: Unexpanded Vic, Disk drive or a sdiec interface and a c=64 keyboard overlay (optional).
Description: A monophonic musical synthesizer that gives 2 octave playable control over the vic chips 4 voices.
Features
-Works with c=64 keyboard overlay
-No noticeable latency
-Editable control over the octave, note layout and tune of the vics 4 voices
-Save and load up to 12 presets
-Downloadable .zip folder contains microvicious2.d64 disk image, a printable instruction manual and a type-in
version with instructions
Download-micro vicious 2.0
Discusion
aeb
Post by aeb »
Dropout - Traditional block game for unexpanded VIC 20
PAL version
NTSC version
Dropout is tuned for fast play and implements many block game features that were not yet common in the golden 8-bit era:
- SRS (Super Rotation System: each piece has 4 orientations, except square)
- Hold function (swaps current piece with the last piece stored in HOLD box)
- Wall kicks (smoother play near walls or locked structures)
- Lock delay (pieces do not lock instantly)
- Infinite spin (movement and rotation reset the lock delay, easier to move)
- DAS (fast key repeat with delay)
- Shows next 6 pieces
- Ghost piece (white outline showing where the piece is dropping to)
- Pre-rotation (Rotate controls are read during the 100 ms line clear delay)
- T-Spin recognition (T-Spin clearing 2 lines is worth more than 4 lines)
- Most L, J, S, Z twists are possible, not all thoroughly tested though
- Scoring system similar to many recent block games, except no combos
- TGM-style randomizer: previous 4 pieces are less likely to appear again
Four game modes:
[F1] Standard Long Play - start slow, level up to insane speeds
[F3] 40 Lines - clear 40 lines as fast as possible, under a minute is great
[F5] 2-Minute Challenge - score as many points as you can in 2 minutes
[F7] Master Mode - start at level 15, if you make it to level 24 you're good
Keyboard controls:
[Shift] Hold - move current piece to hold box / swap with hold box piece
[Z] and [X] Rotate counter-clockwise / clockwise
[J] and [L] Move left / right
Hard drop - drop piece instantly
[M] Soft drop - speed up piece falling
Joystick controls:
Up - Hard drop
Down - Soft drop
Left/Right - Move
Fire - Rotate piece counter-clockwise
PAL/NTSC differences:
- PAL version does a graphics hack to display 8x12 pixel square blocks
- NTSC version uses native "flat" pixel ratio and 8x8 blocks (and 60 Hz timer)
Have fun! :roll: :lol: :oops: :cry: :P :x :D :) :shock: :D :lol: :wink:
http://www.cncd.fi/aeeben/download/dropout.zip
