Updated BASIC and KERNAL disassembly
I've been meaning to post my copy of Lee Davidson's commented ROM disassembly, here it is.
The main changes are to replace the LAB_xxxx labels with their common equivalents, e.g. LAB_FFD2 with CHROUT. I've used the 'Programmer's Ref Guide' and also 'Computes Mapping the VIC'. For some labels I've invented something appropriate.
I find this invaluable when writing assembly programs, hopefully others will too. Updates or corrections are welcome.
- combined_ROMs.zip
- (105.71 KiB) Downloaded 180 times
- pixel
- Website: http://hugbox.org/
Re: Updated BASIC and KERNAL disassembly
This is a revelation compared to the old version. Thanks a lot!
Glad you think it's an improvement. I think Lee did a tremendous job with his commentary, I've learnt a lot from reading it.
I notice that the C-64 equivalent is hosted on GitHub, would people prefer me to put it up like that?
This is awesome. Thanks for taking the time to make and post it .
I forgot to include the makefile I use to compile and verify that it is byte identical to the original ROMs. I can provide that if it's useful to anyone. It also generates a list of equates that I then include in programs I write.
That would be really useful, it would be a great reference to test my assembler.srowe wrote:I can provide that if it's useful to anyone.
- pixel
No doubt about that! No wonder he didn't go through the trouble of naming the labels. It must have been quite exhausting already.srowe wrote:Glad you think it's an improvement. I think Lee did a tremendous job with his commentary, I've learnt a lot from reading it.
Here's a new zip file with the Makefile and the generated include file.ajordison wrote: That would be really useful, it would be a great reference to test my assembler.
- combined_ROMs.zip
- (111.85 KiB) Downloaded 153 times
- pixel
A thing that just occurred to me is that if the labels would end with a colon it'd be easier to navigate around with text searches. But the way you've done it, it could be converted easily with sed (the UN*X tool).
ctags can handle 6502 assembly, works fine with the file as it is.
- majikeyric
- pixel
Is it OK to put the definitions file into Bender (which is MIT licensed)?
BTW I noticed that assigned labels like
didn't make it into `combined_ROMs.inc'.
USRPPOK = $00
Sure, I can hardly claim copyright on them, they're either the public names from the Prog Ref or scavenged from other books.pixel wrote:Is it OK to put the definitions file into Bender (which is MIT licensed)?
Odd, they are in the zipfile I madeBTW I noticed that assigned labels likedidn't make it into `combined_ROMs.inc'.Code: Select all
USRPPOK = $00
[srowe@gilraen temp]$ unzip ../combined_ROMs.zip
Archive: ../combined_ROMs.zip
inflating: combined_ROMs.asm
inflating: Makefile
inflating: combined_ROMs.inc
[srowe@gilraen temp]$ head combined_ROMs.inc
FAC_EXPT = $0000
USRPPOK = $0000
ADDPRC = $0001
ER_2MANYF = $0001
FAC_MANT = $0001
ER_FOPEN = $0002
ADRAY1 = $0003
ER_FNOTOPEN = $0003
ER_FNOTFND = $0004
ADRAY2 = $0005
- pixel
Sweet. Will put it in with reference to your work, of course. Will trim my finger nails and get new contact lenses.srowe wrote:Sure, I can hardly claim copyright on them, they're either the public names from the Prog Ref or scavenged from other books.
USRPPOK = $00
- e5frog
- Vic 20 Nerd
- Website: http://channelf.se
Can't really find the right spot when I want to know what JSR $FFxx is pointing to for example. All addresses are replaced by "elite-labels".
