I made my own interface card!
Unfortunately, most programs I wrote for Vic-20 hardware projects that I did in the 1980s were cassette based and they have been lost or damaged over the years.vic user wrote:do you still have the programs for your projects?
chris
I few things I burned to eproms, but I have erased and reused most of these.
User port control routines are usually pretty short anyway and easy to write.
it looks like you just have to deal with two memory locations, which is nice.User port control routines are usually pretty short anyway and easy to write.
tonight i hope to set up on my breadboard a LED circuit using a transistor as the switch.
if it works ok, then off to use an i/o line from the vic to feed that base current, and hope the LED comes on!
chris
Dont forget current limiting resistor from user port to base of transistor and a current limiting resistor for the LED.
If you have MOC3020 chip handy you can connect this to user port and switch 120vac loads up to 100ma. This is a really cheap way use computer control of 60watt lamp without clunky relays.
Connect a triac to output of MOC3020 and you can handle AC loads of several amps.
If you are not used to working with AC line voltage ........ be careful
Does this look right to be able to turn on/off the LED from an I/O line on the vic?
+ 5 volts------------------------resistor----------LED-----collector
I/O line--------------------------resistor----------base
emitter----------------GND
here is a better representation:
http://web.ncf.ca/ex809/circuit.bmp
thanks in advance for any replies.
chris
chris
well i hooked up the circuit last night, and the transistor works, but i am going to have to get a multimeter tonight.
i can get the LED to light up, no matter which I/O line i use to plug into the base, and can even get it to light up just by holding the wire with my fingers!
i then replaced the +5 volts line with an I/O line to power the circuit, and although the LED was faint, i did get a closed circuit.
poking the particular I/O line did not seem to affect the power level either.
i picked I/O line 8 (PB7?) so its decimal value is 32, yet no effect.
chris
chris
- Schema
- factor
i feel so silly.
once i used the proper value for 2^7 i got it to work
although i can turn on/off an LED just using an I/O line for power, i can see why using a transistor makes sense.
i am now having fun getting two LED's to blink at different rates etc..
i should have bought more transistors
chris
p.s. i want to thank everyone who has helped me get to this point. i am having a huge blast interfacing the breadboard to the vic!
chris
i'll be picking up more transistors tomorrow during lunch break, but right now i have 4 LED's hooked up and wrote a little program that takes a random value from 0 to 255 and pokes the value into a sound register as well as to the I/O ports, (then a random delay loop) so I get a crazy sound and light show
one thing i noticed, is how much faster the program is when i poked a variable having the value 37136, rather than using 37136 directly, for example.
chris
chris
