I'm finally nearing a point in life where I may have time to indulge in one of my favorite hobbies again: the Vic.
A question: Jim Butterfield's Machine Language for Beginners seemed to always be the 'go to' for learning 6502 back in the day. Is this still the case, or is there a more modern work?
The last time I coded for the 6502 was on the Atari 8-bit machines back in the late 80s, so to say that I'm dated is an extreme understatement.
6502 Assembly
- William_X
- Occupation: IT Tech
6502 Assembly
"I've been ionized, but I'm okay now." - B. Banzai
Re: 6502 Assembly
If you already have a background with 6502's then you might only need the minimal material in the "VIC 20 Programmers Reference Guide". Part of the beauty of 8-bit processors is that you can recall most of the instructions and how they function even if you have a elderly brain like mine.
You're probably going to need the PRG or "VIC Revealed" because you'll need to learn the specifics of the OS and peripherals like the VIC graphics.
