Sorry for arriving late....
I bought a FE3 kit but never assembled it. Here is the board scan:
Front:
http://s29.postimg.org/9m50r7yuv/FE3_R3_front.jpg
Back:
http://s29.postimg.org/eal0meo1j/FE3_R3_back.jpg
Ignore the "r3" that's a typo. The board is Rev 9.
Steve
FE3 - Recovered Technical Documents from lost website
- e5frog
- Vic 20 Nerd
- Website: http://channelf.se
Re: FE3 - Recovered Technical Documents from lost website
Nice, did you choose any particular DPI for the scans?
600dpi greyscalee5frog wrote:Nice, did you choose any particular DPI for the scans?
Steve
- Groovydrifter
Last versions from SD2IEC Firmware and Bootloader, sources included, can be found here: http://www.nightfallcrew.com/tag/shadowolf/?s=sd2iec
ebay slang 101: not tested=not working
It is much more affordable than you think to have these things completely assembled at the fab.Groovydrifter wrote:Yep.
I think most of the chosen parts were to keep the cartridge in the "DIY kit" kind. Probably designing the board to be factory built with most, if not all, SMD components, will make it even cheaper... but then you'll probably need to find a 1000 buyers. I somehow like the old school look of the board. I recently bought a similar card for MSX computer built with SMD components that look like islands in a green sea. It was twice the price and works like a charm, but looks a little "alien" plugged in the cartridge slot of the MSX.
- Groovydrifter
Then most of the modern hardware for old computers are excessively expensive. Ah.. wait... I already new that. [WINKING FACE]
