Noisy VIC Power Supply
JohnnyRockets
Occupation: IT Manager
Post by JohnnyRockets »
My power supply for my VIC has a low humming sound or buzzing sound when it is on.
Is there a way to get rid of this?
This is my second power supply with this hum. :(
Thanks!
JR
Pedro Lambrini
Post by Pedro Lambrini »
Usually it's just an age thing and is harmless. If I recall it's something to do with the coil transformer being cracked over time or something...
It does seem a bit of bad luck that both your PSU's buzz though. That would drive me crazy too!
shem
Post by shem »
Yeah the buzzing/humming is normal that's why commodore used to fill the old brick psu's with epoxy resin it put a stop to the buzzing
but a lot of them overheated as a result and the epoxy made it impossible to replace the caps and regulator
I'll take my cart to go thank you ;)
Wow, I never understood that whole epoxy thing. Honestly, I hadn't given it much thought, but I am now glad to know why they did that.
JohnnyRockets
Thanks all!
Wished I could fix it, but it isn't that bad...
Thanks!
JR
callan
Post by callan »
Jeff-20 wrote:Wow, I never understood that whole epoxy thing. Honestly, I hadn't given it much thought, but I am now glad to know why they did that.
I can't find the quote at short notice, but I recall the comment from Bil Herd (C128 / C264 design engineer) that "It was very hard to set fire to a big hunk of epoxy".
Callan
