Two (I think) rareities
macc
Post by macc »
Time Slip by Pheonix Software and Head On by Hi-Tech (same game as listed in Gamebase but by Computermat)
Cant find much, if any info on this searching, anyone know if they are worth anything or need preserving?
macc
Post by macc »
took a couple of pictures;
Image Image
And they both work too!
I'll have to check when I get home, but I believe both need preserving for GB20. I can make an offer for both anyhow, if you like? As you say, hard to gauge value though...
macc
Post by macc »
Ok Mayhem, cheers
Well, out of precaution, I can take both. Unless you want to preserve them yourself...?
macc
Post by macc »
Ill send you a Pm Matt
Vicman *1970
Re: Two (I think) rareities
Post by Vicman *1970 »
I know it's an old Thread....
@Mayhem : Did you figure out the Keyboard-Control for Head On by Hi-Tech ?
Tape-Image is in Gamebase but i have no luck to find out the controls...
Any idea ?
I'd have to go back and see... may not have time before I go on holiday.
Vicman *1970
there's no hurry
but please do not forget :wink:
eCC-Imagepack-Designer
Done: Vic20, N64, Philips VG-5000-G7000-G7400, SordM5, Amstrad GX4000
Progress: Atari 8bit, Enterprise 64/128, Dosbox
I think Z X control the speed of your car, and @ : ; / move you up/left/right/down at the intersections (where relevant), from looking back at the listing.
