VRT file format
VRT file format
Due to the usability issues with VIC-20 cartridge files (especially in the two-part case), I created a new file format for VIC-20 carts: VRT. The format is heavily based on the CRT format used by C64 emulators and some modern hardware such as 1541 Ultimate. Initial VRT support and a converter have been implemented in this VICE fork.
The "generic cartridge" type is supposed to handle all the old (pre-2000) cartridges that don't use the I/O areas. The current VRT format (version 1) assumes that BLK 1-3 & 5 only contain one chip (RAM or ROM) of either 8kB or 4kB in size; in the latter case, the data is mirrored to the other 4kB of the range.
Are there any "generic" carts that don't fit in the above description? If so, please point them out. Of course, feedback on other flaws is welcome. Let's work out to quirks before suggesting this for VICE inclusion.
Note: I still haven't owned a working VIC-20 or even used one so I'm certainly not the right person for this project. Besides, it's 15 years too late.
Bonus: vrtfe3, a proof-of-concept VRT loader for the Final Expansion 3 cart. Contains fe3.vrt for testing loading a VRT using an emulated FE3 attached as a VRT.
Sorry for not giving any feedback on this yet. I think it looks very good.
One thing though. There should probably be some way of handling wrapping and/or partial decoding within memory areas in the generic cart type.
4KiB of ROM in a 8KiB bank or perhaps even 4KiB of RAM in an 8KiB bank.
At least the ROM case is common. Perhaps there even was 2KiB ROMs?
These are the "generic" examples I collected (but never really solved) when looking at a cart format a long while ago:
The first example is "Pharaoh's Curse", a 16KiB cartridge
populating the full BLK3 and BLK5 lines.
Generic cartridge
Size - 16KiB
Load address - $6000-7FFF, $A000-$BFFF
The second example is "Vicmon", a 4KiB cartridge
populating the upper half of the BLK5 line.
Generic cartridge
Size - 4KiB
Load address - $B000-BFFF
The third example is "Super Expander", a 4KiB cartridge
with 3KiB of RAM populating the lower half of the BLK5 line and
all RAM1-3 lines.
Generic cartridge
Size - 4KiB + 3KiB (RAM)
Load address - $0400-$0FFF (RAM), $A000-AFFF
The fourth example is "Rabbit Tape", a 2KiB cartridge
populating the I/O2 and I/O3 lines.
Generic cartridge
Size - 2KiB
Load address - $9800-$9BFF, $9C00-9FFF
The fifth example is "Mikro Assembler", a 2 * 4KiB cartridge
with 3KiB RAM populating the BLK3, BLK5 and RAM1-3 lines.
Generic cartridge
Size - 4KiB + 4KiB + 3KiB (RAM)
Load address - $0400-$0FFF (RAM), $6000-$6FFF, $A000-AFFF
Seems like the format (and xvic) is woefully inadequate to handle all of these cases. Should have guessed.
In any case, the format needs to specify the new fields so an update is pending.
This should work already.
If it appears as mirrored on $Axxx, it works.
Ouch! A truly nasty case.
While support for ROM/RAM-on-I/O could be added to the generic type, I'd shove this under "tricky" to keep the generic type FE3-supportable.
Hmm. If the ROMs are mirrored to the other 4kB of their respective ranges then this works already. Can anyone confirm if this is the case?
Unfortunately. Since the generic type is fine for a large bunch of cartridges and is simple enough to be "supported" by FE3 (and maybe Mega-Cart / Vic Flash Plugin too), I'm tempted to shove the problematic cases under an another type under the working title "tricky" (naming suggestions welcome).tlr wrote:There should probably be some way of handling wrapping and/or partial decoding within memory areas in the generic cart type.
If mirroring the smaller ROMs to the whole range is close enough, then the 4kB case should already work on the current VRT version; I'll add 2kB too if such a cart (using BLK1-3/5) is pointed out.4KiB of ROM in a 8KiB bank or perhaps even 4KiB of RAM in an 8KiB bank.
Thanks, this is just the kind of info I was looking for. Some comments on them:These are the "generic" examples I collected (but never really solved) when looking at a cart format a long while ago:
"Pharaoh's Curse"
"Vicmon"
"Super Expander"
"Rabbit Tape"
"Mikro Assembler"
After a closer look...
I parsed part of that as:
...in the sense that the same RAM is visible in both places. Fortunately the load address line disagrees. As such, this should already work, assuming $Bxxx is a mirror of $Axxx.
Before realizing this I updated the specs (and converter) to include the "tricky" type that can handle such oddities. Update coming in about two weeks.
Depending on the mirroring, these examples should be doable with the "generic" type. Any more corner cases?
all RAM1-3 lines.
Generic cartridge
all RAM1-3 lines.
No, that's not how the SE appears in the CPU address range. Rather:nojoopa wrote:I parsed part of that as: [...]
- 3 KB additional RAM in the range $0400 .. $0FFF (corresponding to the /RAM1, /RAM2 and /RAM3 signals on the expansion port),
- 4 KB additional ROM in the range $A000 .. $AFFF (lower half of BLK5, possibly mirrored to upper half - could someone else confirm?)
I have 2 SE carts, and Mike is correct, but 4k rom is not mirrored, $B000-$BFFF are random bytes.Mike wrote:No, that's not how the SE appears in the CPU address range. Rather:nojoopa wrote:I parsed part of that as: [...]
Ah... I should have known that: it wasn't for no reason, that I relocated Programmer's Aid to $B000 some time ago.buzbard wrote:$B000-$BFFF are random bytes.
What you see actually is bus noise, i.e. SE only maps into the lower 4K of BLK5, and is deselected in the upper half. This enables to map in yet another expansion cart in the upper half. The relocation of PA to $B000 frees BLK3, so BLK1..3 could be completely filled with RAM.
Thanks for confirming the SE case.
Meanwhile, I added RAM/ROM-on-I/O support for the generic cart and specified/implemented the "tricky" cart. Updated VRT docs here. The adventurous may check out the code from the git repo [1] and give it a spin.
SE should work now by using
and attaching the .vrt. The other mentioned cases have similar "solutions". So far the testing has been minimal as I'm not familiar with the carts.
The current tricky cart specs should allow any sane RAM/ROM cartridge to be represented. Things such as "every other byte is RAM, every other is ROM" falls outside the vague definition of sanity. I really hope no such abomination exists...
More corner cases? Other feedback?
[1]
vrtconv -o se.vrt new tr se.prg r0
[1]
git clone git://viceminus.git.sourceforge.net/gitroot/viceminus/viceminus
Somehow missed your request here.groepaz wrote:someone throw a few such cartridge dumps into my direction pleaseSomeone may want to backport this to VICE.
What type of dumps do you want?
There are a lot of dumps here: http://www.zimmers.net/anonftp/pub/cbm/ ... index.html
Here's a couple I whipped together in a hex editor:
Avenger.vrt
Battlezone.vrt
I think these conform to nojoopa's specifications.
Ray...
Avenger.vrt
Battlezone.vrt
Ray...
- Pedro Lambrini
So, is the hope that this will be a future standard for Vic cart images? Will that mean that emulation will have to support both old and new formats? Does this affect the future of GB20 at all?
Just curious.
Just curious.
