The colour RAM is connected over an extra 4-bit data bus to the VIC chip, and shares the lower 10 address pins with the 14-bit VIC address bus.
That is the reason the colour RAM changes its base address along with the screen RAM base address. Take a look at the lower 10 address bits:
4096 = %000100|0000000000 37888 = %100101|0000000000
7680 = %000111|1000000000 38400 = %100101|1000000000
Furthermore, the following correspondence holds:
VIC address range CPU address range
$0000 ... $1FFF $8000 ... $9FFF, i.e. BLK4
$2000 ... $3FFF $0000 ... $1FFF, i.e. BLK0
It is also not able to access the colour RAM as text or character generator data, as an analog switch separates the normal data bus and the colour RAM bus during VIC access.
Even though an external +3K RAM expansion maps into BLK0, it is not accessible by VIC either, as it is on the 'wrong' side of the data bus and address bus buffers, which also separate the VIC and CPU side of both busses during VIC access. They're necessary, because the 6502 cannot tri-state its address bus.
An internal +3K expansion, as done in parts 1 and 2 of my VFLI mod, fills the hole between $0400 and $0FFF on the VIC side, making the complete BLK0 available for graphics data.
