Preserving my old games
- Mayhem
- High Bidder
- Mayhem
- High Bidder
Ok, here it is. Maybe someone will have better luck with it.
http://sleepingelephant.com/denial/memb ... 5Side2.zip
Hi- have you not managed to get it to work?
I downloaded it- saved it to desktop- started up VICE
Then in VICE i went into File> autostart tape/disk image- then click on either PACMAN or SCRAMBLE- this will load the loader - you'll need to type RUN and hit return (on scramble the cursor color is white- an old copy protection tip).
Anyway, the loader will run and auto run the main program which should load up for you to try.
Hope this works for you- worked fine for me.
Cheers -thanks for hosting it!!
- Mayhem
- High Bidder
I think the issue is that if you attach the TAP in Vice and just try to LOAD the games normally, then the emulator finds nothing; evidently the transfer process was not 100%. If you do click on the individual files they will load however, as you said.
Anyhow, I've extracted the relevant programs in question and separated them into individual files per game. You can download the archive here. All I need now is a full name to put them into GB20, and an approximate year when you wrote them
