Black screen :-(
Black screen :-(
I had a Vic that worked until it fell off a shelf that collapsed, everything seems fine, not even any scratches on the case, opened it up, fuse ok, all chips reseated, no loose wires but on power up, black screen, tried with a cart in, no difference, any ideas where to start looking?
Re: Black screen :-(
Probably a small crack somewhere on the PCB (mainboard, that is). Time to get that multimeter out!macc wrote:I had a Vic that worked until it fell off a shelf that collapsed, everything seems fine, not even any scratches on the case, opened it up, fuse ok, all chips reseated, no loose wires but on power up, black screen, tried with a cart in, no difference, any ideas where to start looking?
Bacon
- Vic 20 Hobbyist
- e5frog
- Vic 20 Nerd
- Website: http://channelf.se
- e5frog
- Vic 20 Nerd
Start with the things that have the largest mass then...
Who knows what that bumped caused and if there were poor joints already, did you try turning it on and then press/wiggle all components and see if anything happened?
- e5frog
- Vic 20 Nerd
If the board is OK and no components are loose - what component would break first if it was dropped?
If a component has come loose and lifted the copper and solder from the PCB, tearing away the trace so that there's no connection and then flexed back again - that will be very hard to find...
Did you measure the fuse, maybe it's just almost OK. What if you short the fuse for just a short while, any difference?
I guess if you'd followed my acquaintance Bacon's advice and checked ALL traces with a multimeter you'd be about done now. If you don't find anything else that's probably what you need to do.
I'd check GND and +5V on all components first to see if they all have power.
Maybe also see if Ray Carlsen has any general advice about a "black screen" unit. Maybe it was OK after the fall but something else just happened to fail when you turned it on.
