Zipstick joystick with the VIC
bobbyd
Post by bobbyd »
I assumed that any "DB9" connector joystick would work on the VIC20 but after reading some on here I might be wrong.
I had a black (with yellow buttons) microswitch Zipstick joystick with my C64 years ago and was going to buy one for my revamped VIC20.
Does anyone know if this will work ?
thanks
Bob
Pedro Lambrini
Post by Pedro Lambrini »
Yep, they'll work. As far as I know pretty much every 9 pin joystick will work on the Vic. All C64 compatible sticks definitely do. :)
There's contention with regards to Megadrive/Genesis controllers but even Master System pads work on the Vic.
PS: Welcome aboard!
bobbyd
Post by bobbyd »
thanks fella,
I assumed they would, but wanted to check first,
not interested in a pad.
sticks came first in my eyes !
cheers
Bob
Post by Vic20-Ian »
Not sure they do.
Some Spectrum and MSX joysticks look the same but aren't.
Many models come with 2 leads one grey and one black 9 pin connector so you can tell which to hook up.
Machine specific joysticks won't always work on Commodore / Atari.
Stick with Commodore or Atari compatible sticks.
